C5: Street Touring Unlimited (STU) Build Thread
#281
I am running Borg Motorsports offset bushings and was using Van Steel camber plates, which I retained on the front of my car. But I'm trying to keep with eccentrics in the rear so I can get the camber close to equal left to right. I torqued the rear eccentrics to the spec of 107 (Set the torque wrench to 110 ft lb) and 2 events later, the eccentrics slipped evidenced by markings I made.
My right side has more camber than the left, so I was thinking of using the kit on the left side. and an eccentric on only one location. But, how much torque sauce have you wrenchers put on the eccentrics without negative ramifications? I will do at least the 125 ft lb spec of the front since it's the same damned bolt. But, anyone go higher than that? Otherwise, I'm thinking I'll just set the torque wrench to 135 to well account for error due to torque wrench or friction. ~25% higher torque perhaps is enough to keep from slipping.
#282
Mine slipped at 3 different events and alignments over the first two years I ran mine. This past winter I set the alignment with the eccentrics. Then I ordered a 3/16 thick 1 foot square sheet of aluminum scrap off ebay. Cut out my own blocks and drilled them exactly to match where the eccentrics were. I used a 10$ digital caliper from harbor freight to measure it all up...worked like a charm. No slips and no overtorqued bolts or stretched threads.
#284
Supporting Vendor
I have never slipped mine. On Hoosier's.
F the torque spec, tighten them as much as you can. And yes, a little Blue Loctite on the bolt isn't a bad idea.
