Starting Nitto NT01 tire pressures?
Any recommendations?
C7 2015 Z51
Weather looks to be 80-85
I ran the r888s years ago and Ive heard these are of similar construction. The r888s liked a little higher pressure.
C7 2015 Z51
I run 28 psi in my C5Z06 in Texas. Incredible grip (~1.2 to 1.3 Gs in the corners, but I am also running a lot of negative camber and poly bushings). Those are cold temps, mid 30s hot
Last edited by SunnydayDILYSI; 06-14-2015 at 08:52 PM. Reason: Did not note cold vs hot in orig post
32 to 34 hot
