C6 rear diffuser
Old Jan 7, 2016 | 10:24 AM
383's Avatar
383
I know i know i keep bringing this up but its cool stuff
Ive been reading about vortex generators and it seems like a larger diffuser angle could be used if VGs were put at the throat. Has anyone tried this with a yarn tuft /camera test to see if its effective?
Old Jan 7, 2016 | 01:27 PM
jlutherva's Avatar
jlutherva
Default Here's mine
I got this with the Pfadt car. I installed for the first time this winter. The undertray goes all the way up to the rear edge of the doors.
Jim
Old Jan 7, 2016 | 03:51 PM
fmcokc's Avatar
fmcokc
Read this:
https://www.google.com/url?sa=t&rct=...g7760eotTslcHw
Old Jan 7, 2016 | 09:05 PM
383's Avatar
383
Originally Posted by fmcokc
So it seems like steep angles work with higher ride heights. I wonder how a short and steep one will work like the one ill make. The twin vortices sure make the yarn tuft test harder
Old Jan 8, 2016 | 08:00 AM
el es tu's Avatar
el es tu
Jim
any pictures of the underside?
Are you keeping the rear valence and stock style exhaust? Modding that area can gain you a ton of space.
Old Jan 8, 2016 | 04:43 PM
383's Avatar
383
nope its all going. I have some plastic sign board im going to use for fitting then mold carbon from it
Old Jan 8, 2016 | 04:51 PM
el es tu's Avatar
el es tu
these are low cost and will exit right below the bumper cover when mated to the stock axle pipes:
Thrush welded:
2.5" (part# 17659) or 3" (part# 17660)
Old Jan 8, 2016 | 05:05 PM
383's Avatar
383
SWEET thanks dude!
I haven't had time to measure and search what would work and not be too loud
Any sound clips of yours assuming you use this one
Old Jan 8, 2016 | 07:18 PM
el es tu's Avatar
el es tu
no sound clips but they are supposedly the same design as flowmaster 40s
most auto parts stores should have them in stock for about $30 -$40
Old Jan 8, 2016 | 08:01 PM
jlutherva's Avatar
jlutherva
Tom,
I removed the backup lamps and mod'ed the valence to use the existing brackets that Arron Pfadt was using for mounting. The car had a valence on it when I got it. The exhaust is essentially straight pipes with some small resonators in front of the X pipe.
Pics of the underside - Uh no. I'll take some next time I remove it.
Jim
Old Dec 24, 2020 | 06:15 PM
ygto1's Avatar
ygto1
Nice idea. I'm going to be making mine soon.
