Vitesse Throttle Controller
IMO worthless product. All it does is alter the ramp up rate between pedal input vs actual TB opening rate. I much rather have more modulation on exit. Throttle is not an on/off switch
I've always found these sort of mods and/or tuning practices to get "more throttle response" pretty goofy. If you have a stock TB/more or less stock car they tune the throttle to be more or less linear in power delivery with TC off or in comp mode (on the C5 at least). Why would you want it any other way? I don't get why anyone would want 90-100% of power at 50% throttle actuation-- it's not an on/off switch like another guy said. This is one big advantage of having an electronic throttle vs cable.
If you get a tune they should be able to fine tune this, plus normal driving/TC on vs TC off/comp mode should have different tables to reference, to allow for even more fine tuning.
Here's a snap of a C5Z06 tune, primary on the left, alternate (comp mode/tc off) on the right. Pedal position vs actual throttle blade percentage. If you do that maths of pedal position vs throttle AREA open, it should be much more linear in nature.
read some of those posts, still think it is waste of money.
By theory you can map the entire throttle opening by just 20% of pedal travel and the remaining 80% are dead, still doesn't make the car faster. Majority of us still prefer to have linear modulation.
This is nothing new; back in the day with cable/wire driven TB, companies pushed out smaller or eccentric throttle pulley for marginally quicker opening. Similar concept happened in motorcycle market which they sell 1/4 turn throttle tube on the clip on.
BMW E46 M3 had different throttle map for their "M performance button" too.
All of them only give the driver a false sense of quicker opening.
Ultimately, throttle response has a lot to do with cam phase timing and intake track length. A certain improvement on throttle response is stay natural aspirated and have Individual throttle bodies.
sorry for the huge pic too, couldnt figure out how to get a small thumbnail version on here.
I have this installed. Everyone is correct in the sense there is no extra power, but the stock throttle mapping is not linear and this unit offers something a tune can't, which is on-the-fly adjustability. For example, I set it at SP3 around town, which feels about right for 1-to-1 throttle linearity, which I prefer to the stock setting. On the highway, I like SP 5 or 6, which provides a bit more aggressive mapping for easy cruising and passing adjustments. In traffic, I set it at ECO 1, which allows for easier transitions in stop-and-go (just slightly less aggressive than stock). SP0 maintains the stock mapping. Overall, there are 16 options in addition to stock to adjust the throttle response to your liking. I have a manual, but those with autos report downshifts are more responsive to throttle inputs.
It is an easy plug and play install, relatively inexpensive and works as advertised. I haven't used it on the track yet, but have done some practice heel-and-toe around town and the extra responsiveness at initial throttle tip-in is appreciated. It certainly doesn't turn the throttle into an on/off switch unless you want it to (SP 9 setting).
My apologies for the off-topic post....
Semper Paratus! Thank you for your service!
Was on the Kukui for Search & Rescue covered the Pacific region....then volunteered for Vietnam on the Bering Strait...two tours in Vietnam....Bering Strait was given to the Philippine...Kukui decommissioned....4 years served...GI Bill put me back to school..
Sorry folks, Coasties reminiscent...
Hopefully, more input/insight on original subject.
Semper Paratus
Now....what was this thread all about!???
controller
I have one, It does make the throttle more responsive, if you set it that way. For those who have not tried it, If you do a log of your commanded throttle input vs actual blade you will se a lag in response time, all this does is remove the response time, makes it feel like a drive by cable rather drive by wire. HP tuners doesn't recommend fooling with the settings for the DBW not sure if EFI live does it. bottom line is its a cool mod if u got 100 hanging around.
victorf (09-18-2015)
