Looking for LS7 dry sump opinions
Hey guys,
Can't seem to find a lot of info on the forum about this, so I'm going to throw it out there.
Looking to add an auxiliary scavenge stage to my 06Z. Has an ERL/LG built engine, done by the previous owner-forum member and great guy.
Notice I have a lot of smoke out the pipe at WOT on the track and the common consensus seems to be adding an extra scavenge stage, it has the stock set up now. Car has an ARE tank and sump with the ports available for the extra stage.
I see belt drive auxiliary setups from ARE and AVIAID are available, it looks like the AVIAID is quite a bit less expensive.
Has anyone had experience with either of these and could offer insight or suggestions?
Thanks!
Adam
Thanks!
Adam
I seemed to have good luck with a high volume low pressure pump, along eith a better pickup and the aviad insert for the stock 08 tank. However, i didnt run hoosiers. It was fine for close to street tire lap record oiling though.
Talk to Gary Armstrong at Armstrong Race Engineering. He makes the best dry sump systmes in the world. You may have heard of his company as ARE. They have scavenge pumps etc. Jerry
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Should be able to just get the pieces from either us or ARE. It would need the solid belt tensioner, the pump, pulleys, then you need a line from the pan to the pump and from the pump to the tank. The one line replaces the blue plug you see in the pan now. Depending on what you use for a line, most have had to grind part of the cradle away to allow proper clearance for the line.
If this is the car I am thinking about, I believe it has a low tension oil ring setup in it, which might be partially to do with it, and that could help it.
