AiM Sport Solo DL Smarty Cam
Old 03-14-2016, 08:43 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default AiM Sport Solo DL Smarty Cam
The Solo DL is a more advanced data logging model. The Solo DL will connect to over 300 supported ECU models, including OEM CAN, OBDII, and the most advanced third party ECU's in motorsports. Thus giving you a Solo with all the above features, plus the ability to record up to 100 additional channels coming from your ECU (model pending). The Solo DL will also seamlessly interface with our popular SmartyCam video recording with real-time data overlay.
Similar to the AIM Solo, the Solo DL is an automatic lap timer based on GPS technology. The Solo locates its GPS position, identifies the track from the internal list of the main world tracks and starts automatically sampling lap times. In addition, the Solo DL, with the included OBDII connecter, logs all data coming from the ECU. Real-time GPS data (laptimes, speed, accelerations) and RPM's, throttle, water temp., oil pressure, etc. are displayed at once! (Note: OBDII connectivity and data availability may vary based on make/model of vehicle.)
The AIM SOLO automatically records and displays crucial data to improve any type of race performance: speed, performance and regularity on both open and closed circuits (ex. rally). The AIM Solo can show: speed, lap and split times, predictive lap time, best lap, and acceleration. When the race is over, all of the data can be downloaded to a PC and analyzed in the included Race Studio 2 software using graphs, tables and also real GPS images. Plus, thanks to the built-in track database it is no longer necessary to assign GPS coordinates to sample lap times: just switch Solo on and it detects the coordinates using the GPS, automatically recognizing track, lap and split coordinates.
• Integrated track database
• Accelerometer: tri-axial +/- 6G
• Size: 98x78x30
• Weight: 220g, battery included
• Display resolution: 128x64
• Waterproof
• Rechargeable lithium battery
• Battery duration: Up to 4 hours with back light, up to 6 hours without backlight
• External power: 12 Volt
• Magnetic base
• Memory: 16 MB
• Usage temperatures: -20°C/+60°C
Kit Includes:
• USB cable
• Mounting Bracket
• Wall charger adapter
• OBDII ECU harness
• Race Studio 2 Software
http://www.xplosiveperformance.com/-...er_p_3677.html
The SmartyCam HD has been engineered by motorsports enthusiasts who spend their lives at the track.
After years of intensive development, AIM Sports has released the AIM SmartyCam HD, an all new camera designed specifically for motorsports. Unlike a traditional action camera that has been designed for everything from jumping out of airplanes, to surfing killer waves, the SmartyCam HD has been engineered by motorsports enthusiasts who spend their lives at the track.
Just like the original AIM SmartyCam, the SmartyCam HD automatically overlays all of your essential track data: speed, RPM, lap-number, gearshifts, and much more. With the huge selection of overlay layouts, you can fully customize your track experience to watch over and over again. Capable of operating as a standalone unit (optional GPS antenna required), the SmartyCam is also fully optimized to work with your existing AIM Data system. Simply plug it in with the CAN-cable and instantly access all of your vehicle information.
The SmartyCam HD features a proprietary lens that was developed exclusively for motorsports. Ever notice how generic action-cameras make nearby objects look far away, making it near impossible to determine if a track is straight or curved? The telecentric lens has six elements to help reduce this distortion. Add to this a global-shutter CMOS sensor that helps reduce that sickening wave effect caused by track and engine vibrations and you get truly track oriented video!
And about that video quality - how's 1280x700 pixels at 30 fps sound? Such high quality usually comes at the price of memory card space. Not in the SmartyCam HD. Using H264 compression, a 1-hour recording uses as little as 1.5GB (4GB with high-quality setting). The camera comes with a 4GB card, but with SD cards available in sizes as large as 128GB, that means up to 30 hours of high-quality recordings per card! Auto stop-start, and Auto-Off capabilities help make sure your data-space and battery life aren't wasted.
The attractive body features a front mount, color TFT display. Why a front facing viewfinder instead of the standard rear placement on all other cameras? Simple - where is it easiest to check the camera position from the driver's seat? The machined aluminum body is also designed to resist the rigors of motorsports. Water, shock and temperature resistant, the SmartyCam HD can handle whatever you throw at it. The compact body is only 87x63x48mm and weighs just 250g.
Each Kit Includes:
• SmartyCam HD Camera
• 4GB SD Card
• External CAN Cable or External power cable (select above)
• 110/220v Battery Charger with AC power adapter
• Software RaceStudio2 CD
Technical Specifications:
• Video format: H.264 1280x700 pixel @ 30 fps
• Display resolution: 128x128 pixel
• Lens: Telecentric with 6 elements
• Angle of view: Wide-Angle 84°
• Internal battery: Rechargeable lithium battery - 1.040 mAh
• Battery charge: 700 mAh 12V
• Battery duration: 70-80 minutes of recording
• External power: 9-15 Volt
• Memory: Up to 128 Gb
• Memory capability: 1.5 Gb (1 hour low quality recording), 2 Gb (1 hour medium quality recording), 4 Gb (1 hour high quality recording)
• Accelerometer: Tri-axial ± 5G
• Usage temperatures: -10°C/+60°C
• Auto Power ON: Yes, if connected to an AIM logger
• Auto Power OFF: Yes
• Auto Start/Stop Recording: Yes
• Dimensions: 87x63x48 mm
• Weight: 250 g, battery included
• Waterproof: IP6
http://www.xplosiveperformance.com/-...HD_p_3679.html
Old 03-18-2016, 08:18 AM
Former Vendor
St. Jude Donor '13
Old 03-21-2016, 08:49 AM
Former Vendor
St. Jude Donor '13
Old 03-24-2016, 08:22 AM
Former Vendor
St. Jude Donor '13
Old 03-28-2016, 08:00 AM
Former Vendor
St. Jude Donor '13
Old 03-30-2016, 08:07 AM
Former Vendor
St. Jude Donor '13
Old 04-01-2016, 09:11 AM
Former Vendor
St. Jude Donor '13
Old 04-02-2016, 08:12 PM
fstrthnu01
fstrthnu01's Avatar
Plugged into a C5's OBDII port, what data can be read?
Thank you,
John
Old 04-04-2016, 09:09 AM
Former Vendor
St. Jude Donor '13
Thank you,
John
John
Unfortunately the Solo DL will not read any data from the C5 ECU it is compatabile with GM ECU's 05 on.
Old 04-07-2016, 08:48 AM
Former Vendor
St. Jude Donor '13
Old 04-14-2016, 09:15 AM
Former Vendor
St. Jude Donor '13
Old 04-18-2016, 09:59 AM
Former Vendor
St. Jude Donor '13
PM's Sent
Old 04-20-2016, 08:18 AM
Former Vendor
St. Jude Donor '13
Old 04-26-2016, 09:17 AM
Former Vendor
St. Jude Donor '13
Old 04-29-2016, 09:31 AM
Former Vendor
St. Jude Donor '13
Old 05-04-2016, 09:34 AM
Former Vendor
St. Jude Donor '13
Old 05-24-2016, 07:48 AM
Former Vendor
St. Jude Donor '13
Old 05-31-2016, 08:10 AM
Former Vendor
St. Jude Donor '13
Old 06-14-2016, 08:56 AM
Former Vendor
St. Jude Donor '13
To AiM Sport Solo DL Smarty Cam
Quick Reply: AiM Sport Solo DL Smarty Cam
