Pirelli slick size
Pirelli slick size
I just came across a good deal on some 305/680/18 Pirelli scrubs. Will these be a good fit on 11/18 ccw front wheels? Asking before I spend money to mount. Any one have personal experience?
It's going to depend on your ride height but that's a pretty tall tire for the front. I'm running 305/660 in the front and there's very little room in front of the tire to the fender. You also might have some rubbing under compression, I don't with the 660 but I have 800lb springs up front.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
680 is a 26.8" tall tire....same height as the rear of a base C6 so that might be a bit tall. Most use the 660 like Kphayes1 had said, as it is only 25.9" tall and closer to what a stock front tire would be.
tires
I ran 305x 645's and 305x 660's on the front of my C5.
Even the 660's are tight on a lowered C5.
I ran 315x675's and 315x680's on the rear.
This is especially true if your car is lowered from stock height.
