How to remove a rounded caliper bleeder valve?
Any tips or tricks would be appreciated. I'm guessing this community has done this more than most others.
Is it as basic as squeezing/crushing with vice grips and turn? This was what I heard in the c5 forum.
I bled it three weeks ago for Pocono. It rained all day so the system didn't see to much heat or use.. It's the passenger front caliper, so I got 3/4 bled for next weekend. I'm concerned if I damage the bleeder more I may not be able to get parts in time for next weekend. If it's easy peasy with vice grips or some other way I'll give it a go
Thank you guys, I feel like a newb asking, but I guess I still am one 😃
bleeders
Vise grips and heat if needed. Napa probably has the bleed screw you need. You could take the other side out and take it to NAPA or GM dealer to see if they have one. Then if yes you vise grip out the bad one. With proper wrench size rounding out should never happen. These also do not need to be gorilla tight either. You do not want to damage the caliper seat. Also if tracking hard we replaced OEM caliper because they spread annually. You will get much more life doing some HPDE and not going 10/10ths on the them. If you notice more pad taper and pad knockback and more pad drag when car is cold those calipers are ready to replace.
mikeCsix (05-22-2016)
Thank you guys, the light of a new day has helped since I found this yesterday. I was using a flare nut wrench and probably tightening them somewhere near gorilla tight. I put a socket on it and it got further down on the bleeder and I was able to loosen it. I'll stop at Napa today and see what they have for replacements and grab a few extras.
I am getting some pad taper. From one end to the other I am getting a 1mm difference at about 3/4 total pad wear. 7mm vs 6mm, pads are 10mm new (carbo XP10). Not sure if thats a lot or little. I'm starting year 3 of HPDE's running between 4 and 6 multi day events a year.
I also flip the pads during my prep for every event, inboard to outboard, left to right
After about 4 track days, here's my pads (DTC30) on stock calipers. Not sure if something was going on with the left side or I really need to start flipping in/out/left/right.
Front Right
Front Left
Front Right
Front Left
Oh yeah, was my first time experiencing it as well. I was super paranoid by the last day and had to skip the last session.
near threshold braking is 99% in a straight line. When I see pads like that differing from left caliper to right I think of caliper issues. With the Oems we know we get caliper spreading and that effects the wear patterns like what you see. There is of course natural taper. That is why there are multi piston calipers to control that taper. Pads are best the 1st 50%. As you loose the pad you increase heat, increase stopping distance, loose pedal modulation and increase heat fade and can even loose the sweet spot of your heel toe downshift routine. Pads are so easy to change everyone should learn how to do it and carry extra pads. If you don't want to invest intend to run pads down 50% and keep a 50% pad in your go box for a spare if you need them. It is not a bad idea to bring an old front rotor too. When we raced the C5 in T1 racing on stock brakes we killed a set of pads every weekend and rotors in 3 trackdays before they cracked. The real reason for the big brake kits is not to stop shorter but to stop the same on every brake application and have durability and safety and a consistent pedal.
Ya know the C5 brakes aren't bad on a gutless ABS deleted Camaro. Much more consistent pedal than I ever had on my Z06. My calipers are spread out pretty bad though, I really should replace them, but even I don't get that level of disparity from left to right. I'll run them below 50%, but I can tell when they start nosing over. That's when they get replaced and demoted to spares in case the above ever happens. FWIW I never go to the track without spares, worst way to get caught with your pants down.
Since those pics I took everything apart and checked it out. Didn't find any spread or anything abnormal really. No radial pad taper, so don't really think the caliper had spread. Did a full rebuild and put in SS pistons for good measure. Next time out, going to use real race pads and flip them at the end of the day and go from there. I'm thinking/hoping that maybe a pin was just sticking a bit (I replaced all of them during the rebuild) and a pad with higher heat tolerance will wear better.
We've definitely derailed this thread from the original topic, eh?
Here's a fun test: remove pads and install caliper. Next, try to slide that caliper in both directions. If it doesn't float freely, it's either hardware or pad bridges. That's how I ID'd my rear pad issue. I had a bent bridge. This was the only scientific way to ID the problem.
I have recently moved to the AP Kit for the front but still have OEM for the rear. Keeping the caliper pins greased, replacing their dust boots and making sure the cooper anti-rattle clips were straight was all part of my OE Brake ritual.
I never flip pads and I may no longer flip tires despite owning a tire machine and spin balancer. I have found that it takes too long to get good mating of the flipped brake pads wearing into the rotor and it takes too long for the tires to wear accordingly. All during that time you are slow and fighting the car. Running pads 50 to maybe 75% seems to be as much as you can expect and get the most performance. Once that sweet spot is gone the fun is over. I see why now running things with cheap consumables makes so much sense because you really never wear out the consumables but you use up the good part.
I too have found that flipping pads leads to a lower and softer pedal than before, but maybe I am not doing it right or maybe it takes a lot longer than I expect to get the pads to mate to the rotor.
I have also found that different pads taper to different degrees, some significantly less than others
