steering rack
Old Jun 8, 2016 | 11:44 PM
fatbillybob's Avatar
fatbillybob
Default steering rack
Anyone know what is under the redcap in this mechanism? I have broken tools trying to get the cooler line off the rack. I need to break it loose with heat but do not want to destroy the rack. I would rather destroy the line. But with heat i should be able to get the line fitting off.
Old Jun 9, 2016 | 12:03 AM
froggy47's Avatar
froggy47
Lurk, sorry don't know, bump your question.
Old Jun 9, 2016 | 11:12 AM
Gordy M's Avatar
Gordy M
Isn't that the return line from the PS cooler?
Old Jun 11, 2016 | 11:14 PM
kmagvette's Avatar
kmagvette
I don't know what is under the red cap, but the Magnasteer stuff is dang close to where you want to apply heat. I would suggest cutting the cooler line and yank the rack so you can get it on a bench or other convenient place to work on. There, perhaps judicious application of Free-all, mild heat, and better access to the nut will help. I have a metal cooler line if you want it; it is your for shipping. I put -6AN fittings on the rack so I never have to deal with the crowfoot flarenut wrenches anymore.
To steering rack
