Auto Blip and Road Course is Heaven.......
#81
Supporting Vendor
Supporting Vendor
Hello Everybody, what kind interest is there in the Autoblip for your Manual transmission Corvette's that see track day duty? RDP Store gives two thumbs up to the AUTO-BLiP. IT is a really slick unit and very effective on the track.
It is a new patent pending electronic device that will automatically blip (open) the throttle when downshifting gears on an automobile equipped with a manual transmission and an electronic accelerator pedal system. AUTO-BLiP works by monitoring your automobile’s accelerator pedal position sensor (TPPS), brake pedal, and clutch pedal, and only blips the throttle when both brake and clutch pedals are pressed simultaneously. AUTO-BLiP reduces mechanical wear and tear on manual transmissions, improves vehicle stability when downshifting gears, and eliminates the need for the heel-and-toe driving technique.
http://www.rdpstore.com/p-9334-auto-...ownshifts.aspx
#83
Supporting Vendor
RDP Store (08-31-2017)
#85
#86
Supporting Vendor
Supporting Vendor
SCCA Run Offs are coming up quick at the end of September. Want to shave some time in the brake zones at Indy, get an Auto-Blip. Free next day shipping on all Auto Blip orders. Please use the promo code ..... blipsav ... too save some dollars and get free shipping .... please note your year and sub model of your Corvette
#88
Supporting Vendor
Blip your Way to Indy and save with RDP Store.........
RDP Store (09-18-2017)
#91
Supporting Vendor
Roadracing at Laguna Seca today ............. shift like a pro with the Auto blip for you manual equipped track day car.
#92
Supporting Vendor
Auto-Blips are such an easy install, it does help to be a skinny guy. It is easy peasy and the units work so well.
#93
Supporting Vendor
#94
are these allowed in racing? I know the rules are different between classes, etc. so just seeing if anyone knows of a certain sanction or class that it Isn't allowed.....NASA, SCCA, etc. etc.
#95
Supporting Vendor
From all our research and our wide spread customer base that uses them, it is legal across the board. This does not make the transmission a sequential which does inquire weight penilties in likes of SCCA and NASA
#96
Supporting Vendor
Track newbies this is a perfect modifications..........check it out and reduce your lap times
#98
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I use it on the track (Watkins Glen). 2007 Z06. What it does it allow you to worry about other things, instead of heel-toe. Now I can focus on my braking, release, shift and turn-in and not blipping the throttle. So in that sense, it has improved my times and let me focus on other areas to improve. It also never misses and is adjustable (delay and amount of blip). I have some video I can post if it would be helpful.
RDP Store (10-02-2017)
#99
no I'm familiar with how it works, just curious on lap times. What have your improvements been?
Reason I think it would be better for non newbies is the stuff you lost but would love to hear time differences.
#100
So now I don't have to even think of heel-toe and can focus on improving other areas of my driving (which has lowered lap times) and completely avoid a miss heel-toe mistake.
RDP Store (10-05-2017)
