Holding the steering wheel during a DIY alignment..
For those do-it-yourself'ers, what are you using to hold the steering wheel straight when you are adjusting your alignment?
No matter what mine always moves a little when setting toe. Ive been using some bungee cords to hold it but they arent doing the trick. Its always when i adjust the passenger side for whatever reaso that it moves.
I don't do my own alignments, but if you google "steering wheel holder for alignments" a couple of them show up. I remember a shop using one of the holders that hooks onto the seat or the pedals.
Good luck!
Good luck!
I roll the car forward a good ways to let it self center or hold it to where I believe center is and then adjust accordingly. Of course you need a relatively flat surface to do that.
I have a cheap set of ratcheting straps that most use to hold light things in the back of a pick up. They have plastic coated hooks on the ends. My car has a rear (4 pt) roll bar I hook the ends to the bar, one end on the drivers side, one passenger side so the force is spread wide. Loop through the steering wheel and use the ratchet to apply tension. As long as I have the ends on either side of the car it works well. Dont use too much tension - might bend steering wheel.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Maybe I'm the odd man out, but I have never had the steering wheel move when doing alignments...
Do you use slip plates under the tires?
I get the toe where I want it then center the wheel adding turns to one side and subtracting the same amount from the other.
I just measure total toe as well and only usually need 1 or 2 test drives at the end to see if the wheel is centered. I count the turns and make equal adjustments side to side.
Received 8,928 Likes
Bill
Joshboody (04-07-2017)
I don't know how the wheel does not move for others unless you have super slidey plates. I've used various slidey methods which wheel easily turns with no power for caster but always moves (instead of tires) when doing toe.
I had this same problem setting toe last weekend. I eventually asked one of my kids to hold the wheel but he still let it move. Lots of crawling out from under the car and looking through the window to recenter the wheel.
Once you've got total toe set put the steering wheel straight and then use something long and straight (I use a 5ft level) and put it up against the middle of the front tire parallel with the ground. Sight down it and see where it hits the rear tire. Then check the other side. It's not super precise but it's good enough that I've never had to reset toe settings because the steering wheel isn't straight.
There is no need to hold the steering the wheel. The toe is set by adjusting the tie rods to get the 'total toe'.
Once that is done drive the car a short distance and note the angle of the wheel and then adjust the tie rods an equal amount of turns to compensate. You can't just hold the steering wheel straight while adjusting the tie rods and expect the steering wheel to remain straight.
