JOC Yellow Sway bars with Square tire set up
Anyone out there running the Johnny O'Connell (Yellow) sway bars with a square tire set up? I'm running Nitto NT01's 315 square and will be adding the JOC sway bars for Road course use.
I am assuming I'll start with the rear bar set to the middle setting and see how it handles but if any of you have experience, Please share.
Happy Thanksgiving!
Happy Thanksgiving!
Always start with the middle setting and then see if the pushes or is loose and then adjust accordingly. Sway bars only affect your mid corner handling (at transition). What shocks do you have?
I have the Pfadt Featherlight Coilovers. For track I run them at 33% off Full stiff front and rear. Pfadt suggests a starting point for track use of 40% off full stiff as a starting point (both front and rear)
The Pfadt starting points are usually pretty good for a baseline. Get a good feel for what the car is doing and pay attention to WHERE it's doing it. I'm assuming those shocks have a compression adjustment so I'd probably go with the 40% stiff front and rear and see how it feels. If the car pushes then give more compression in the rear. If it's loose then stiffen the front. If you are neutral....give it two clicks of compression until either your lap times go down or the car feels too stiff for you to control.
Bossdog (12-04-2017)
I ran the JOC and 315 nittos for years. I ran the rear bar full soft after experimenting. After I put on fully adjustable coilovers I disconnected the rear bar. My youtube videos usually list my suspension setup for my own notes, so you can see how it handles with different setups.
Well, I meant to just send you to my channel. I didn't realize it would embed a video. That video is with Penske's and the JOC front bar only. Look for stuff 2 years old on the channel for pretty close to your setup. JOC, 315 nittos, either Pfadt single adjustable or later Doug Rippie non-adjustable bilsteins both on factory leaf springs.
I have the JOC yellow sway bars and stock Sachs shocks. I run a square setup with 305/660 Pirelli slicks. I have the rear bar on the middle setting and haven't felt the need to change it. The car corners pretty neutrally and I can adjust the angle of the rear end easily with the throttle.
I tend to trail brake so I'm turning in with quite a bit of load on the front tires and I don't like a lively/loose car. I also run some rake on the car (maybe 1/2 - 3/4" higher in the rear, but have never accurately measured it).
