C6 Z06 Aero Options
C6 Z06 Aero Options
For a full set (splitter, side skirts, and full length spoiler) of oem carbon fiber pieces it costs about 5k
For a full set of Katech pieces in fiberglass it is about 3.5k
if you go with acs though which is also fiberglass it is only around 1.5k
heres the acs splitter:
http://www.zip-corvette.com/05-13-c6...-splitter.html
what are the downsides of going with this over the katech or oem pieces?
google danny popp or rich willhoff and check out their rear spoilers
St Jude Drive every year
C6Z Aero
If you want dedicated track car aero for your C6, check with those who used to run the C6 in the Pirelli World Challenge racing series. LG and Blackdog both did and there may be others. They have first hand experience in what really works.
I have seen a lot of Vettes, Nissans, Porsches, Camaros, Mustangs etc have wings just bolted to the hatch deck or trunk lid with no real issue and with very good results.
Aero is very complicated and the amount of weight that is actually pushing "down" on the wing is a lot less than the total rear downforce generated by the reduction of lift and increase suction of the car to the ground. Aero is synergistic so the wing is just one part of the equation.
I would not dissuade anybody from mounting to a deck or trunk lid if a frame mounted design is not an option.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I do think the frame mounted wing is desirable, but the Viper ACR-E has the BIGGEST damn wing I've ever seen on any race car and it's only bolted to the rear hatch. If you've ever grabbed an open hatch of a Gen 5 Viper, it is very light and you'd never think it would withstand the drag of that giant wing. And the results speak for themselves as it is one of the fastest street legal cars to ever hit a road course.
Location: If you don't weigh in you don't wrestle Road America
Aero is like any other component, some systems are designed better than others - an APR wing deck mounted wing will work, is it the best way to mount it -no- but it will work. The airfoil is mounted to the rear of the car and it creates more than enough downforce to settle the rear of the car.
The systems offered by LG or Good Aero (I would include Blackdog here but they stopped making aero bits for these cars) are a big step up, the air foils are much stronger and more efficient, being chassis mounted they transfer any force directly to the chassis which is further back than a deck lid mounted unit so there is some extra leverage as well. So the design is better for sure.
I have found that the tough part about aero is getting enough front end downforce to balance out the massive downforce a wing generates. Since we don't have the $$$ for wind tunnel testing what I do to check the aero balance on a car is to take burst photos of a car at the end of a long strait before the braking zone. My favorite spot is at the end of pit lane at Road America it's a level spot and the car is still on the gas at that part of the track - here are some shots that I've taken to check aero balance.
You can see this BMW is running too much rear wing and it's causing the rear end of the car to squat a ton in comparison to the front.
Here you can see the wheel gaps are fairly even front and rear for a better balance.
For fine tuning you can measure the fender gaps and something on the side of the car (in the case of the car above the numbers on the side of the car are 10" tall) this gives you a gauge on how much the suspension is squatting front and rear and you can adjust from there.
Ultimately all this is going to do is make sure you are in the ballpark - but it's better than just guessing
You will get more from a vented hood than that tiny little splitter.
Venting the hood gives quite a bit of downforce and gets rid of the C6 lfront lift that these cars are notorious for.
i have to agree (vent hood is more DF than ZR splitter)
also you didnt mention if it was for show or track.
if you dont want to go full blown race wing, look at the C7 Z06 replica spoilers that "C7 carbon" and "Innovative Creations" makes
http://www.c7carbon.com/for-0513-c6-...on-fiber-p-672
https://www.innovativeautocreations....erbill-spoiler
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
A true frame mounted wing (ACS, LG etc) will produce the most down force, but some groups don't allow them so you have to design a NASCAR style blade spoiler. Here is my car with that style and it's based on the rules we have in the Optima series. A frame mounted wing will provide more down force with less drag, but this is what we have to work with.
We also have a much larger splitter on the front that started with the Katech piece as a base and then we made an extension and tray from a composite material with lots of additional braces and brackets. It's all tied into the front frame rails and you can stand on it. It's also fairly easy to warm up and bend back into shape if you smack it on something.
Here is a pretty interesting video with visual real world examples of how aerodymanics work. This ex F1 engineer explains more with water and a spoon and a pad of paper than a lot of internet experts will ever be able to or even get the actual physics correct.
Regarding the front splitter....if done incorrectly without an under tray, you may actually be making things worse and increasing lift and stagnating the air in your engine compartment causing heat issues.
Andrie (12-05-2017)
