Light weight C5Z
#81
obviously there are lots of organisations that let you run without a cage if you are in timed lap/ HPDE / autocross etc type events. Other organisations allow street cars to run events without cages. Road cars are built to certain crash standards and have crumple zones as part of the crash safety factor. Just because they dont have a full cage doesnt mean they arent safe to track.
When you run certain types of competition a full cage is obviously mandated by all organisations.
If you will only track with a full cage then thats your decision and thats ok but the rest of the world is allowed some flexibility.
#82
We all take risks every day and some we select (riding a bicycle next to a major road, driving an un-caged car really fast, dating a hot chick) and some we don't. Freedom is a hell of a drug.
Sledgehammer is testing at COTA this weekend. Stay tuned for more updates since the car has been on JennyCraig and SlimFast both for the past three weeks. <EEEEEK>
Costas
cars and such...
#84
Testing went really well. The GSpeed crew was prepared to test a lot and test we did. Ride heights, diffuser, wing angles, canards, splitter length, ***** on dampers....we have a LOT of data to sift through to correlate with the debriefing notes so we are fully prepared for NASA Nationals at COTA in a few weeks.
More soon!!!
Costas
cars and such...
More soon!!!
Costas
cars and such...
Chets LS3 (08-30-2018)
#85
Supporting Vendor
To say the car has undergone a transformation the last 3 weeks would be an understatement. Heres a few pics. Full write up with all info and knowledge gained AFTER NASA nationals next week. Thanks to all who follow, this car has pushed forward some cool ideas, and its neat to see our customers gain from it.
Heads on, measuring for pushrods.
Shortblock nearing completion at HPR. ATI balancer saved 2 lbs. Nice. Rotational too.
MAGNESIUM C6Z Cradle! Saved 12 lbs, and got us into a C6 rack as well, which are easier to find. Yes, it bolts right up. Lower control arms are IDENTICAL. Drop spindles added 1.2lbs per corner...
Engine out, 9 days before testing. The LS6 lived a good life, its actually going into a fellow competitors ST2 spares bin. It needed a clutch, balancer (Wobbled) and lifters refreshed, so why not change the whole engine?! LOL.
For weight, we chose the LS9 oil cooler setup. This combo is LIGHT (4.8lbs) and cools just fine for 285whp. Its also a lot less work for our condensed timeline.
Finally got the tilton on, what a relief. It drives nice. Stock master cylinder. Not to be driven on track. Thanks to our friends from Bruce lowerie chevrolet for loaning a nice trailer with good slope and a winch... Problems of being located at the track, I guess.. LOL
Cradle in, and engine bay cleaned. We took care to not break the brake lines loose, as the brakes on this car are from another world.
oil cooler packaging.
Checking header fitment. American racing C5 headers clear the LS9 oil cooler.
We chose the LS3 GS drysump for several reasons- it was the lightest drysump of all the options! since HP didnt matter, but packaging did, we have no concerns with it. Its backed by a 3 gallon peterson tank, so starvation isnt an issue. Were using a stock 09 pump/pump gear.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
#86
Supporting Vendor
3 gallon tank. We moved it into the passenger footwell for weight distribution, and for future use of the area behind the tire for Aero, or headers down the road.
New C&R radiator saved approx 12lbs, no fan necessary, but we did lay it down and had to build this shroud.
completed shroud out of the car.
35lbs lost with this Braille G30. Wonderful battery, happy to have found a resilient battery that is light!
Fender wheel house spats. These are worth significant downforce.
Testing 335 clearance. we did not modify the horizontal most surface of the wheel well, per the rules.
more 335 testing.
Aluminum box around the drysump tank. Added 4.8LBS.
Completed laying the rad down, and a little shroud on the back side incase we have a pressure differential we dont know about, which would cause an increase in water temp. Rad is dual pass, extruded core.
Air intake complete. We opted to put the MAF back in, because we have low HP. It worked fine.
Carbon splitter in the works! End product saved 20lbs.
All done, 1am before heading to COTA for testing... 2650 full fuel, no driver.... NOT BAD.
#87
Supporting Vendor
Good Morning from COTA!
We finished chassis testing early, and brought all of the parts to install the diffuser. It wasnt a bolt on affair, we had to literally transfer everything over and BUILD it at the track.
Diffuser on, her current state.
Showing big brother how to do it.
Getting a once over, and a good look at. ZERO mechanical issues. No oil drips or drops. Every session proved fruitful, exactly how you want testing to go, especially after you and the team have thrashed hard for a week.
Testing theory on splitter length, vs Drag... GOOD LESSON LEARNED. More on this later.
The car is setup fantastic. we picked up OVER 10 mph ENTERING the esses. Over our time from May, we picked up almost a second from turn 2 to turn 10. Incredible.
The purpose of the test went as planned. To work out the kinks, and make sure we had the data and results we wanted prior to heading into nationoals. Luck favors the prepared, and we feel we are very prepared. The car is fast, and the driver Paul Costas did a great job working through the setup and giving feedback as we progressed through the weekend.
We are down a few mph on the strait, which we have a few suspicions why, but we did pick up over 10 mph from the start, to the end of the weekend. 280 rwhp wreaks havoc on your aerodynamics, and COTA is 60% corners, 40% WOT, believe it or not.
The following 2 users liked this post by GSpeed:
Conrod Liberator (09-10-2019),
HP RESEARCH (09-06-2018)
#88
Those studs on the valve covers that hold the plastic covers on might be worth a few ounces.
Just kidding. The car looks amazing and the attention to details is incredible.
Edit because I'm a dork and had some of them and a scale handy:
Almost an ounce per pair.
#89
Supporting Vendor
C6 aluminum tunnel plate saved 2lbs over c5 steel!
#90
Supporting Vendor
Baby clutch and 12:1 helps engine acceleration!
nsogiba (08-12-2019)
#91
I can't rid myself of that "pull key" message. I have tried slow turn of the key and that works. I have tried adding a resistor that matches my key into the circuit and that does not work...very strange! Anyone else have a fix?
#94
https://youtu.be/4nK5uaWQCUQ
last lap, Adam runs a 1:17.4, lots of traffic. I believe theoretical was a mid 1:16
#95
So....
COTA went really well....
<goes to fill out Hoosier contingency forms>
Costas
cars and such...
Costas
cars and such...
HP RESEARCH (09-17-2018)
#96
Former Vendor
#97
While we wait on Louis....
BRO! Do you even esses???
Costas
cars and such...
Costas
cars and such...
The following 2 users liked this post by Shortcutsleeping:
HP RESEARCH (09-18-2018),
NSFW (08-12-2019)
HP RESEARCH (09-27-2018)
#99
Former Vendor
Since Paul posted a little spoiler with the video.........your TT3 and TTU NASA champions, Paul Costas and Troy Messer.
#100
We tested before the "Big Show" and here is that story....
http://www.witchdoctormotorsports.com/ch268.htm
Costas
cars and such...
Costas
cars and such...
HP RESEARCH (05-20-2019)
