275/35-18 on 18x10.5 C5Z Speedlines?
Quick question: Will a tire in the 275/35-18 size fit OK on an 18x10.5 C5Z Speedline wheel?
These would be used for the front tires in a C5Z.
That's the wrong direction. Stock is 295 on that wheel. Often 315s are run square with 10.5 z06 wheels up front. 275s are better on 10" wheel and with rain tires to reduce aquaplane. There is no good reason to go narrower unless class rules demand it.
The_Backmarker (08-27-2018)
Yes, this is a class rules thing (Global Time Attack - Enthusiast RWD class). Max tire width is 285mm. I think what I'll do is find some base C5 rear wheels (18x9.5) and use those for the front wheels with either 265 or 275 tires. Alternatively, I might be able to run 285/30-18 on the 18x10.5 Speedlines up front, assuming no clearance issues with the front fenders.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Its a perfect fit. That combo was king back when NASA's TTA class was around. I still run a 275/35R18 on 18x10.5 wheels.
This picture shows a stack of 275/35R18 on 18x9.5 wheels vs that same size on 18x10.5 wheels.
Here are the 18x10.5 on the car:
Thanks for the feedback, guys. GTA's Enthusiast Class requires a tire with a TW > 220 so that limits tire choices. My plan right now is to run Continental ExtremeContact Sports. I've had good luck with them before.
Another question: Will I need to run a spacer up front with the 18x10.5 wheels?
This is good info!
I'm also changing to 10.5" Z06 wheels on all four corners. I'm not thrilled with the suspension height change required to get back to stock rake when going square with 315-30-18's on all four wheels.
I've been considering 275-35-18 on the front and 305-35-18 on the rear. This will be almost the exact same tire diameters as stock for my car (C5 non-Z). So rake will be correct without screwing up the lower control arm angles. I was concerned the short sidewall on the 275's would result in increased understeer (will act like a stiffer spring). Sounds like thats not an issue!
I've been running 275/35-18 square on C5Z 10.5X18's since I decided to try the Maxxis RC1 about a year ago and there are zero issues. In fact the measured width is nearly the same as the 285's I was running before. Most of the R comps run wide to maximize rule limits. The car is fast and balanced. As much as I'd like more rubber and a larger contact patch, I'm not comfortable with the compromises of smashed front brake ducts, fender/tire contact, and loss of grunt from a taller tire. YMMV
RC1's on 10"X18"
RC1's on 10"X18"
The_Backmarker (08-28-2018)
