F/S: 3 quart Accusump oil kit w/ ZO6 cooler
F/S 3 quart Accusump oil kit with ZO6 oil cooler - $750. I took this off my '08 C6 M LS3 prior to selling and do not need it on my '06 ZO6.. Everything included in this kit to hook up inside car behind seat or this can be located under fender. Special configurations include: SS oil-filled pressure gauge used to prevent damage from vibration and pressure surges, the pressure relief valve is connected by a 2 foot 1/8"stainless steelbraided TFE hose that positions any release of oil outside the car, custom mounting hardware were made to attach cylinder & electric valve and Whelen LED light positioned at drivers feet blinks when system is energized. This set up allows for pre-charging the engine prior to start up via a toggle switch that flashes the LED light. System also includes OEM ZO6 oil cooler, OEM oil cooler piping and a Swagelok check valve that directs canister oil to engine rather than first passing through cooler. Reason for selling this: I now have a ZO6 with a dry sump. Once I find a buyer, I’ll plan to write up a description of how all parts can go together with clear pictures and labeling. Prefer local pick up in Bay Area, yet will ship per agreement with buyer. Final note: oil cooler is in great shape. On the exterior, I just cleaned it of California bugs and straightened all bug bent air louvers. On the inside, this system is clean since it has never encountered a blown engine.
I am having difficulty attaching pictures. For the interested buyer, PM me your email address and I can email you a 1/2 doz pics
