C6Z06 oil cooler
C6Z06 oil cooler
how good/bad is the oil cooler on the 08 c6z06? does it make sense to replace it? (air to oil.)
also: is anybody running it in horizontal configuration?
It's an oil cooler. It's not great, but it's better than nothing. A lot of people have seen 280+ on a stock C6Z. My GS (same oil cooler, 100 less hp) saw as high as 270* oil temp on track. They just aren't big/efficient enough to cool a powerful v8 on track. In my opinion, they're also not great because they heat the air going into the radiator. You'd be much better off with a foglight mounted oil cooler.
PRE-Z06 (11-30-2023)
Received 2,058 Likes
I saw as high as 285* with my C6GS when stock in 95* ambient which is about my comfortable limit with 0W40, but the coolant temp was the reason I came off as my comfort level is 240* and it hit 250*. The C6Z06 making 70hp more and revving another 500rpm higher will overheat faster given the same cooling system, really going to depend ambient temps and how hard you’re driving.
well, i think the cooler is quite big, im asking if makes sense to replace it with e.g. a bar and plate setrab. would there be a noticable difference? (i will be placing it horizontally, btw.)
What are your current oil temps? I did a vented hood and ceramic coated headers to help lower my temps. They’re barely warm enough in the winter cruising though as they’re approximately 100* over ambient, but on track they run around 200* over ambient. Is this a street car still?
i found this nice cooler for $300 that would probably fit in there horizontally (no, not on ebay, ist produced in germany). as to temps, i dont really know, because i quit at 280° (running 40 grade oil). its still climbing for sure.
its basically a track day car driven to the track. i plan to do more serious stuff when/if i get it sorted out.
i will be installing a thermostat for that exact reason. then i can run a 50 grade oil.
car has been tracked by po for 10 years. still running like a swiss clock.
Received 8,951 Likes
Bill
thats interesting, both coolers stock? my water magically stays at 99°c (no idea what to think about it) with a 2" rad but i would have no problems getting oil over 300°, i guess. im sure you are a faster driver on top of that. maybe because i usually go to a short track?
Supporting Vendor
Our customers report 300F+ oil temps all the time with the factory cooler. Our oil cooler kit generally gets peak oil temps down to around 250F on track. The highest I have heard of with our kit is 270F peak on track, which is still acceptable.
Some customers do have issues with elevated coolant temps after adding our kit (hitting around 230-240F) because the cooler is so large. This is only a problem on the C6 because of the small front grill opening. It's not an issue with the C5 at all. Several customers have used our cooler in the lay flat configuration and had amazing results. We are developing a lay flat kit we hope to offer soon as well. We are also looking into a fog light area mounted kit. Our test mule recently had a lifter failure, but once we replace the lifters and cam we should be able to get back to testing.
Our coolers have been out of stock for a while due issues with our tube suppliers, but that is finally all sorted out and we are making more right now. We should be shipping them again in the next 2 weeks. We will open them back up for pre-orders soon. Here's the product page: https://www.improvedracing.com/2005-...t-ec6-600.html
Tron Z (12-11-2023)
Tron Z (12-11-2023)
Supporting Vendor
C5 had a smaller oil capacity and no oil cooler, how does that equal better cooling? I could easily hit 300* oil temp in my C5, but of course the coolant didn’t have a chance to get as hot in a shorter amount of time. Obviously an oil cooler blocking air flow to the radiator doesn’t help the latter. So back to you specifically, you’re running an aftermarket radiator?
Supporting Vendor
The brackets will be made for the c6 specifically, so they won't work on the C5. I don't think there is any need for it on the C5 though. Our current C5 kit works great.
my 08 c6z06 has a full size 3" rad of unknown provenience. i do not run engine oil through it.
(my c5 has the stock 1" rad, an intercooler in front of it and i see lower water temps when crusing than on the c6z06. both have 70° stats. therefore i believe it has better airflow management, at least at legal speeds.)
