Cheap camera mount
Old Jun 29, 2004 | 07:04 PM
Falcon's Avatar
Falcon
Default Cheap camera mount
Falcon, the cheapskate has struck, again. Here are some photos of a camera mount I built for my B&K harness bar. Parts consist of 2 conduit hangers, 2 bolts, 3 washers, 2 hex nuts, a wingnut or 1/4" thunb screw, 2-1" standoff pieces and a 4 piece of flat metal. Total material cost, less than $10.
Here are some pictures:
Old Jun 29, 2004 | 09:36 PM
Oyishdog's Avatar
Oyishdog
Default Re: Cheap camera mount (Falcon)
Looks good - much better then paying over $100 for something so simple.
Old Jun 30, 2004 | 06:25 AM
AU N EGL's Avatar
AU N EGL
Falcon you sure that isn't something for robot techno wars??
Get a strap to hold it down to the harness bar. There were a few times I tightend the camera down as had as it could go but forgot to put the strap on and it still bounced and juggled a bit.
Old Jun 30, 2004 | 11:12 AM
94ZR1#444's Avatar
94ZR1#444
Looks like a patent is in order......
Very nice work.
I'd add some old, cut-out inner tube in between the hanger and bar to help keep down the vibration somewhat....
What else do you have in your box of tricks????
Old Jun 30, 2004 | 02:37 PM
Falcon's Avatar
Falcon
Default Re: Cheap camera mount (94ZR1#444)
Very nice work.
Thanks. The rubber insulation probably isn't a bad idea. Thanks for the tip.
I working on a nebulizer, with a duo-diode transfixer set in series with a checkvalve, that will increase RWHP 50% by just carrying it in your car. It's still in the test stage. I'll keep you guys posted on the results.
BTW, necessity is the mother of invention.....particularly when someone is as cheap as me.
Old Jun 30, 2004 | 03:48 PM
AU N EGL's Avatar
AU N EGL
WOW a Nebulizer Gimmie Gimmie Gimmie
Old Jun 30, 2004 | 09:14 PM
varkwso's Avatar
varkwso
Default Re: Cheap camera mount (AU N EGL)
I think I will stick with the cut up old inner tube.....
Old Jul 1, 2004 | 10:45 AM
94ZR1#444's Avatar
94ZR1#444
Aren't nebulizerrs illegal in Troutman???? Don't you have to get a permit for one of them thar things????
Old Jul 1, 2004 | 11:58 AM
Falcon's Avatar
Falcon
Only when we get caught with it in the car while we're hauling our sheep around after sundown.
Old Jul 1, 2004 | 01:56 PM
Lancer033's Avatar
Lancer033
good work
Old Jul 1, 2004 | 03:17 PM
94ZR1#444's Avatar
94ZR1#444
If I 'Come on Down", do I have to bring a sheep?
Old Jul 1, 2004 | 03:40 PM
Falcon's Avatar
Falcon
Nah! (or should that be Baa!) You can use a couple of mine and have a me'nage a' trois. I'll let you have the pretty ones.
Old Jul 1, 2004 | 03:47 PM
AU N EGL's Avatar
AU N EGL
eeewwweeee
Old Jul 2, 2004 | 12:30 AM
Gary2KC5's Avatar
Gary2KC5
What about just using duck tape?
Old Jul 2, 2004 | 08:17 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Default Re: Cheap camera mount (Gary2KC5)
I think the SPCA shot that one down
Old Jul 2, 2004 | 10:52 AM
95jersey's Avatar
95jersey
Default Re: Cheap camera mount (CAJUNY2KC5)
The rubber grommet or some kind of damper is a good idea...and the duct tape works great! The bolts that hold the camera will not hold in a 100mph crash, but racer tape or duct tape will work as good or better than a strap, just not as pretty.
To Cheap camera mount
