Whats a good tire I can race on my car
I want to use a track tire when I go to the Glen and Limerock, whats good and not good to use? I dont think I want an all out slick, but if its worth it I'll try them.
thanks
Jason
thanks
Jason
Originally Posted by John Shiels
Hoosier, Goodyear, Kuhmos, depends on $$$ and rim size for some tires. What rims are you running?
How are those dulop super sports?
When you say all out slick do you mean like a hoosier which is DOT leagel for the first track event or real slicks? Real slicks from GY are 4-500 ea. Street tire stink on the track and vise versa. Hard to find one that does all. How far are you driving to the track? Street tires are exspensive vs. a track tire and burn up fast from rolling under in hard cornering.
Full slicks don't last very long!
Unless you have a "Bunch" of experience, a DOT " R " tire would be a better choice. I've used both Hoosiers & Goodyear GSCS dot " R "s. Other guys have used Kumos... check other posts!
If you have very little experience, stay with your street tires! Street tires will squeal and give you ample warning before breaking loose. Race tires don't make much noise until they are ready to break loose!
Street tires
Unless you have a "Bunch" of experience, a DOT " R " tire would be a better choice. I've used both Hoosiers & Goodyear CSGS dot " R "s. Other guys have used Kumos... check other posts!
Has anyone used those Dunlop supersport tires?
Boy, a lot of tire questions lately!
If you run 17" wheels, your costs will be considerably less. The Goodyear GS-CS1 is an excellent tire. It's true that race tires don't squeal, but the Goodyears (and also the Kuhmos) are very progressive and predictable
When I was running my C5 on the track, racing tires were the best upgrade I did. Contrary to what others have said, you don't need tons of experience to enjoy and be safe with racing tires.
If you're concerned, run for a but with Active Handling on. It's a great system that can help you learn what you're doing wrong and save your bacon in many cases if you really screw up.
Mike
Mike
Originally Posted by cyclerage23
Sounds like a really good point. What are good? I have to replace them any way I have Toyo Proxes on the car now and they seem ok. Any suggestions? These would be to drive around and race on.
I run both Hoosier's & Goodyear GSCS for tracking, but I do use the F-1's in the rain. Hope this helps, have FUN !!!
I ran Mich Piliot Sports for 9 schools and street driving. On the track they take about 2 laps to heat up and stick.
Now I use these tires as my rain tires on the track. I use Hoosiers for the track. I also have a set of GY slicks I am waiting to use.
You could also call Bob Chick in Charlston SC. He has used or slighly used race tires and srcubbs. bout $400 for a set of 4 tires plus shipping for a set of scrubbs. 843-762-7168
A good set of scrubbs could get you one less weekend then a set of new tires for $1200-1400.
Several options.
Several options.
