Tail light Tango
Dennis
Bullshift
Paul
Thanks,
Dennis.
Dennis
Your reply is most interesting, and may answer other issues as well. I've had this vette(64 coupe) for 2 years, and the left t/s has never cancelled. Also, as I was checking the workings of the lights, I noticed an echo (faint) of the right turn signal in the left signal when in operation. Beyond this, when I have to make a slow sharp turn , or a quick turn, ocassionally the horn will sound. Are these issues all connected to steering column/t/s switch problems? Will replacing the switch fix the horn issue or do I have to look else where? Additionally, since we have moved from the back of the car to the steering column in this quest, the bell or second section of the column is loose(slightly. If I go into this change, and it looks like I have to, will this just be a matter of tightening up something or is there a major problem.
Do I need the whole switch and harness that I see in the CC catalog and what do I need to fix the horn?
Thanks for all the help from everyone.
Dennis
Dennis
Well that's exactly what happens with the horn! If I pull on the steering wheel it toots. Thanks for the info. By the way, does the column have to come out to change the t/s switch or to tighten the pinch bolts? Whatever they might be?.
Dennis.
Here is a rough outline of some steps for replacing the signal switch. Others please jump in with the fine points.
Remove Horn Button – just pry off gently.
Remove 3 screws holding horn contact “spring”.
Remove wheel if you want – 6 screws. Can be pulled with the hub attached.
Use steering wheel puller to pull hub after you have removed the hub retaining nut at top of column.
Remove signal lever from housing and switch.
Remove 3 screws holding switch to hub.
Disconnect wires from the harness connectors found on the lower column. Mark these carefully for correct reinsertion into the connectors. You need to thread the wires through the escutcheon (column collar at the dash) and perhaps through the plastic wire mold on the bottom of the column. Mine was missing.
Pull switch out of the housing. The bearing will probably stay with it. New bearing came with the switch I bought.
Check the canceling cam on the bottom of the steering wheel hub.
When putting new switch in make sure it is the “neutral position” to avoid damaging the canceling cam.
Replace column nut and washer, torque and work your way back out.
Good luck.
DZ
Dennis.
Dennis.
Now of course I have another problem. (Couldn't you guess?) My left (drivers) side headlight opens fine, but I have to crank it closed. Very frustrating! Right side works great. Any thoughts on this on?
Thanks, Dennis.
