Chrome plating problems
I just had the front bumpers from my '67 rechromed at a shop in St. Louis. I have never had any parts chromed before, so I may have had unrealistic expectations, but I thought that the bumpers would come out looking like new parts.
The actual result is that the outside, visible face of the bumper looks great. The inside channel of the bumpers (the non-visible part) looks like crap - not chromed, still rusty looking; but I can live with this.
A huge problem for me is the outside corner brackets. These highly visible parts are still rusty - especially the insides of the bracket and the welded nut.
The plating shop told me a story about how chrome plating is directional and they could not do the inside surfaces on the bracket or the welded nut.
Is this right or is the plating guy selling me a load of BS ? Does anybody have pictures of a 'successful' replating job that I could show to these guys.
Assuming the part is straight and dent free, then first it needs to be stripped of the current plating back to the substrate steel. This is accomplished by either reverse electrolysis, or an acid bath. The acid bath will also remove and neutralize any rust. Some shops may also use sandblasting in the prepping process.
The outside surfaces must be free of any major pitting or defects before plating. Polishing of the substrate or other prep work may be needed before any plating is applied. Once the substrate is properly prepped then a copper plating will be applied. The copper will be polished to provide a perfect surface for the nickel plating which follows. After the nickel plating a final chrome finish coat is applied. This is what is referred to as show quality plating, or triple chrome plated, i.e. copper, nickel, chrome.
You could skip the copper process and get it done for less but you still want the piece to be completely rust free before applying nickel/chrome.
Don't expect the back of the piece to be mirror smooth but there shouldn't be any rust present on a newly plated piece and if any was rust present prior to plating it will soon come back.
Here are a couple of names that consistantly get high reviews and do it the right way.
www.paulschrome.com in PA
great explanation and photos of the process on their website.
http://www.advancedplating.com/ in TN
http://www.fini-finish.com/ in MI
There are other good platers out there but I have seen work first hand from these three shops and it's top notch.
Granted, there are some shoddy platers like anything else but don't be too hard on the good guys, it's a learning experience.
Blue67, if those exposed mounts are high spots and inside is real crappy you may have an issue.
