Engine tuning help please
Roy
Set the timing using a vacuum gauge.
Disconnect the line to the vac advance,and attach your vac gauge here (should a port below the throttle plate).
At idle, advance the distributor until max manifold vac is obtained, then back off your distributor timing until vac drops 1" HG.
Cgheck your static timign witha timing light and record. You will now be timed for that engine.
On your carb, i can only tell you what i did with a Holley 650 4777.
I went a lot smaller (6-7 jet sizes) than factory on the primary jets, and installed two sizes up on the primary squirter nozzles. the rest of teh carb was as from out of teh box.
Car ran great, no gas smell, gas mileage was not so great.
Doug
1. Are the floats soldered brass or black foam types (nitrile)? If they're the black nitrile types they may be soaking up fuel and getting too heavy to regulate the fuel coming in to the carb. Replacements would be needed. If they're brass, check that they do not have any fuel in them. They have been known to get leaks in solder joints that separate.
2. With an electric fuel pump you may need to install an inline fuel pressure regulator and guage to regulate the fuel pressure to around 6 to 7 pounds. That's all a carb needs to perform adequately. You may be overfilling the carb.
3. Are your primary jets the correct ones for the engine? You may have jets installed that are too large for the carb model.
4. Did you install a correct gasket behind the power valve in the primary side of the carb block? If not, this will cause a huge internal fuel leak.
5. Is your primary discharge valve under the front primary bowl in good shape? A hole here will cause the symptoms you refer to.
If all of these items check out, I would still look at the carb for any internal fuel leaks. Check the fuel discharge nozzle to see if a pintle or ball is installed under it and that they are free and sealing properly.
Hope this helps.
Hope this helps.
there are several ways to do it. i like the piston stop method. could be that your timing is way out of whack because of this.
Done it, it's right on.
Lars
Drove it for a weekend and while sitting at a light I got a big bang and it quit. Got it started a couple times but not well enough to drive it. I had the old dist with me and stuck it in and off I went with the old problem back. I took the vette dist to Honest Perf and they said the module went out. They put a new one in and curved the dist at the same time. Guess what, back to the same problem with both dist's. Lars, is there a clue here?
