engine stamping etiquette
Old Dec 21, 2005 | 03:37 PM
livin's Avatar
livin
Default engine stamping etiquette
If you were restoring a very valuable and well documented car....
A. Would you re-stamp a correctly dated and cast block, or leave it blank?
B. If you did re-stamp it and it was a great job, what do you tell people (without lying) when they ask if it was original.
C. How do you handle a restamped block at NCRS events. How are Stamped Blocks handled at NCRS events. If you are going to be judged, do you just keep your mouth shut, or what?
JUST CURIOUS?
Old Dec 21, 2005 | 03:43 PM
vintagecorvette's Avatar
vintagecorvette
Documents or no documents, if the original engine is gone, then it is a non original motor and should be represented as one. I see nothing wrong with putting a correct replacement engine back, but trying to represent it as original is wrong. If the car is restamped, then someting in the future, it will be represented as an original engine. I would replace the engine and leave the pad blank, you can still top flight with an incorrect pad.
Other with more knowledge will most certainly have more to say on the topic.
It is one the ignites much debate.
oWEN
Old Dec 21, 2005 | 03:52 PM
ghostrider20's Avatar
ghostrider20
I take it you are talking about finding a block to replace the un-serviceable or missing original block.
I would stamp it with the the date of the engine re-build, and the suffix of the options for that motor, and that is it.
Tell them that it is a NOM (NON ORIGINAL MOTOR) that has been re-stamped to replicate the original motor.
C. How do you handle a restamped block at NCRS events? How are Stamped Blocks handled at NCRS events. If you are going to be judged, do you just keep your mouth shut, or what?
This answer should be obvious, from what we learned in Sunday school when we were 4. TELL THE TRUTH.
I wish there was a protocol for proving, notarizing, documenting an original stamp pad, then having it re-stamped as it was prior to decking. This way the original motor, could be decked and stamped if needed. I am re-building my original motor, and if needed, wish something like this was offered.
Mark
Old Dec 21, 2005 | 04:37 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
A. I would never attempt to pass off a cloned motor as the original. That would preclude restamping.
B. & C. Would then not apply.
Old Dec 21, 2005 | 05:28 PM
Seaside63's Avatar
Seaside63
From what I have learned about NCRS judging, (and yes Chuck G, I am beginning to rethink my approach ) here are some bullet points.
  • The block stamping is worth up to 88 points.
  • Like other aspects of the car, the NCRS is looking for a condition that represents the state as it left the factory (or as delivered).
  • The NCRS guys state that they do not guarantee "originality" only that they judge the appearance of originality.
So, for Judging you might want to be quiet because like any other aspect of the car, why would you want to point out a flaw for the judge to see and possibly deduct you for?
--For example, would you purposely say, "I know this looks like lacquer paint but it's really urethane base-coat/clear-coat", knowing that you could possibly lose all your paint points?
But for Selling then I agree you ought to tell the truth.
I think this way at this time because Judging is a hobby game where you're presenting a restoration (or re-creation) and you're being judged on how good a job you did getting the car back to the as delivered state.
If someone says you're cheating by not pointing out the flaw then you're only cheating yourself.
But Selling has moral and legal implications. You're cheating another person. In my book that's never cool.
Old Dec 21, 2005 | 05:56 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Amen and hallelujah!! You've SEEN THE LIGHT.
NCRS judges the appearance of originality, in all aspects of the car, not just the engine. You've got interior, exterior, and chassis too.
NCRS never has "guaranteed originality" or certified any cars. Chuck
Old Dec 21, 2005 | 08:29 PM
Lynn Mobley's Avatar
Lynn Mobley
After reading all this, I wonder why searching for correctly dated replacement manifolds, carburetors, radiators, and even brand new reproduction dated windows, windshields and mirrors all seems to be ok. Why is this engine block stamping not the same as this? What am I missing?
Old Dec 21, 2005 | 09:17 PM
SBR's Avatar
SBR
I see your point but the importance of an ORIGINAL block stamping is that it tells you without question what the car is, ie 435, L88 etc if there is no authentic paperwork to go with the car.
Old Dec 21, 2005 | 09:38 PM
John McGraw's Avatar
John McGraw
Seaside63,
That has been my thought process as well. Why on earth would someone participate in flight judging, and leave those points on the table? I also, can not see the difference between hunting down the correct alternator, carb, wipers, glass, ect, ect ,ect, and restoring the stampad to it's original configuration. As long as there are points associated with the pad, people will make every effort to make a restored pad that will pass judging scrutiny.
Regards, John McGraw
Old Dec 21, 2005 | 09:42 PM
ctjackster's Avatar
ctjackster
Old Dec 21, 2005 | 09:48 PM
67vetteal's Avatar
67vetteal
Default What's Original?
Years ago, (45), as a young lad I was rebuilding a Model "A" Ford pickup. We always looked for "Ford" script parts to replace worn or missing items. Not to fool anyone about originality but only because that was the way Henry built it! Same should be the rule for "true" hobbiests. Zora liked them"as built"! So do I. Al W.
Old Dec 21, 2005 | 09:58 PM
magicv8's Avatar
magicv8
I'd tell tourists and judges it's an original 61, 57, or 67 engine (whatever) and let them figure it out. That doesn't mean it's THE original engine that came from the factory in your car. It is an original Chevy engine. Even NCRS allows resto engines. It only has to appear original. Otherwise what's the point of Corvette restoration. The seat and door vinyl, the paint, the tires, the battery - none of that is normally original to the car. The engine is just another assembly. On a SURVIVOR(R) it may be, but IMO a lot of that is faked.
IMO if you are selling the car, you should tell the prospective buyer.
PS Zora had COPO and factory modified cars. Call it your own COPO car.
Old Dec 21, 2005 | 10:14 PM
iniguy's Avatar
iniguy
JUST CURIOUS?
This problem is why real documented cars so valuable...and they will continue to rise (restored or unrestored) As for the stamping code I've never had a problem finding a fake. I would admit all to a buyer but those snooty judges should know what their looking at...bottomline many on this forum know the cars better than the judge.
Old Dec 22, 2005 | 12:00 AM
vettebuyer6369's Avatar
vettebuyer6369
Maybe I've worked too much white collar crime, but obtaining a Top Flight while knowing it's not original is obtaining the certification through fraudulent means. Most people who don't engage in Clintonesque double-speak would in fact call that "cheating."
And before you continue your self-serving, "cheating is OK" justifications, remember that you are actually obtaining a certification which WITHOUT QUESTION increases the value of the car, meaning there is actually a monetary value on what you are cheating for. So save the "it's only points" BS.
Cherry-picking what has "moral and legal implications" is always convenient.
Old Dec 22, 2005 | 12:42 AM
Seaside63's Avatar
Seaside63
Think of these two scenarios...
1) You find a 1967 Corvette body "tub" in a field with its front and rear body sections gone, no glass or interior, just the tub -- with a good vin and trim tag.
Alongside that tub is the original engine, with perfectly legible stamp pad and casting numbers. But it's only the block.
You take it home and build an entire car around it.
2) You find a perfect complete car with ALL its original parts in preserved splendour including impeccable documentation. You even uncover owner history and some old color snapshots in the glove box.
But, sadly, its engine block is missing. Only the block.
You take this car home and replace the missing engine with a fully restored, blueprinted engine with an undectable restamped pad.
WHICH IF THE TWO CARS IS MORE GENUINE?
Old Dec 22, 2005 | 12:51 AM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Neither is genuine. Was that a trick question. ?
Of course this all decided by what your definition of genuine is.
IMHO matching #'s is meaningless BS that drives up prices of cars and parts.
Old Dec 22, 2005 | 12:52 AM
Seaside63's Avatar
Seaside63
Originally Posted by Vettebuyer5863
...but obtaining a Top Flight while knowing it's not original is obtaining the certification through fraudulent means....
There is nothing fraudulent in presenting a restored car to a judge who is interested in the appearance of originality.
The NCRS does not certify or guarantee originality. They only judge to a standard. The NCRS allows restoration engines. (they may or may not award all available points)
Is it fraudulent to present the car with a correct, but not original radiator, starter or alternator? Or how about with reproduction parts?
Is someone being fraudulent if they have new carpet or a chrome taillight that was made in Taiwan?
By your statement, any Corvette other than an all-original Bowtie or "Survivor" is a fraud. And maybe even some of them if they ever had the battery replaced or perhaps even an oil change.
To engine stamping etiquette
Old Dec 22, 2005 | 12:58 AM
vettebuyer6369
This would be the self-serving justification I was talking about earlier. You may pretend not to know the difference between a restamped "original" big block and a repro taillight. No point deduction for being disingenuous, I imagine. However, I'm guessing the "R" in NCRS still stands for Restoration (Restorers, actually) so I'll gonna go out on a limb and assume an oil change would not disqualify a vehicle from Top Flight.
Old Dec 22, 2005 | 01:09 AM
Plastic Pig
Live Free or Die
Just to play devils advocate here How is putting the correct "appearing" engine in, NOT "restoration" ?
Anybody that buys a car based on that piece of paper is a complete idiot. To me it's worth less than the paper its printed on. Whose to say the car still meets any of the judging standards at time of sale ? That certificate is a snapshot of the day it was judged and nothing more.
I mean if people are aging tank stickers, stamping and epoxying blocks, and repopping trim tags why wouldn't it be all right to clip the original parts off the car before sale. PT anyone ???????
Old Dec 22, 2005 | 01:18 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Why the preoccupation with this anyway?
What difference does it really make if the same block sat in the car from day one? Just so someone can say: "my car is original, it is better than yours", or "I have something you don't have"? Which, seems to me to be really what it is all about. No, that is what it is all about, from hearing comments over the past 20 years.
In the end, it doesn't matter anyway, everybody dies, and they can't take their cars with them; over time, all the cars will return to the dirt from which they were made, and all is then equal and as if it never was. Enjoy your car while you can, it really doesn't matter if it is original or not.
Doug
