Originality Question???
Old Jan 2, 2006 | 12:29 AM
427/390's Avatar
427/390
From what I can find is that the 430BP trim came with the hard top.
Did you get it with the car?
Bob
Old Jan 2, 2006 | 07:19 AM
Als 67 L36's Avatar
Als 67 L36
Sorry to say but I did not get the hardtop.
Old Jan 2, 2006 | 09:15 AM
Midyearnut's Avatar
Midyearnut
Default '67 Big Block?
Have you made any attempts to locate the tank sticker? If the car has the ORIGINAL tank sticker on it the info you seek will be on it.
HTH, Bob L.
Old Jan 2, 2006 | 09:22 AM
Als 67 L36's Avatar
Als 67 L36
No I have not. But I hear that dropping the tank is quite an ordeal and I am not that mechanically inclined.
Old Jan 2, 2006 | 10:13 AM
SBR's Avatar
SBR
To at least see if the tank sticker is present pull the rubber seal down on the filler neck and look on the driver side of the tank with a flash light to see if the tank sticker is present. Also your block # is 351 which is at least the correct block for your car. Try and read the casting date which is underneath the block on the passenger side it should have a letter then two separate #s. Also as someone suggested have a local NCRS member look the car over to give you a better understanding of what you have, good luck
Old Jan 2, 2006 | 11:15 AM
lemish's Avatar
lemish
According to the trim tag, you can verify the car came with green interior and C07 Hardtop but must not have A31 Power Windows, A82 Headrests, A85 Shoulder Belts, M35 Auto Trans.
Other than that you need an expert to look for the tale tale signs (start with brake lines, etc.)
Old Jan 2, 2006 | 12:34 PM
lawcpi's Avatar
lawcpi
I have a '67 BB coupe that is less than 10 VIN numbers away from your car. The various dates your car has are almost identical to mine. The only significant difference is the body sequence. Mine from St. Louis is in the #2000 range. I have the L36 engine and my pad date is identical to yours. Based on those similarities, good chance it is an original BB in my opinion.
Old Jan 2, 2006 | 10:05 PM
Als 67 L36's Avatar
Als 67 L36
I have spent some time out in my cold garage looking at numbers on the Corvette. I am posting the Vin Pad as well as the Casting date and Casting Number. Good news or bad, what is your opinion on whether this is the original engine and not a restamp. Be honest, I can take it. Thanks, Al
Old Jan 3, 2006 | 12:34 AM
SPLITRAY's Avatar
SPLITRAY
Originally Posted by Als 67 L36
Speedometer is a 160 MPH;
Tach redline is 5700 to 6200;
Oil Pressure Gauge has 0....30....60.
Did BB cars have 60 PSI gauges or 80???
Old Jan 3, 2006 | 12:52 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I think the 390hp, and the 400hp had 60 PSI. the 435, and L88 had 80
Old Jan 3, 2006 | 03:40 PM
Als 67 L36's Avatar
Als 67 L36
TTT
For another look at the engine pad. Opinions?
Old Jan 3, 2006 | 05:29 PM
Grey Ghost's Avatar
Grey Ghost
I thought ALL BB's had 80lb gauges ?
Snap a picture of the drivers side fenderwell and rear end of the car with emphasis on half-shafts and presence of a sway bar.
Like someone else said. Lift the gas door, push the rubber neck to the side and shine a flashlight towards the drivers side top of the gas tank. You might be able to see, if the tank sticker is on there. Then you could pay a local garage to drop the tank for you.
Find a local NCRS judge or member in your area.
Old Jan 3, 2006 | 05:37 PM
  #33
Nowhere Man
Originally Posted by 1967 NCRS Judging Manual
427/390 had a 6000 tach red line and 60 oil pressure gauge. the 427/400 had a 6000 tach red line and 60 oil pressure gauge as well. the 427/430 and 427/435 had a tach red ine of 6500 and a 80 oil pressure gauge
there you go
Old Jan 3, 2006 | 05:45 PM
  #34
ctjackster's Avatar
ctjackster
TTT
must . . . . resist . . . . . . . . posting . . . . . . . .on . . . . . . . . "numbers" topics . . . . . ...
Old Jan 3, 2006 | 06:13 PM
  #35
Als 67 L36's Avatar
Als 67 L36
Looked for a tank sticker but alas, did not see one.
The front sway bar is 7/8" diameter.
Old Jan 3, 2006 | 08:30 PM
  #36
Als 67 L36's Avatar
Als 67 L36
Here are the Passenger's inner fender photos.
Old Jan 4, 2006 | 09:03 AM
  #37
Chuck72's Avatar
Chuck72
another "i thought" statement.
aren' 65-67 big block batteries on the drivers side??
?? chuck
To Originality Question???
Old Jan 4, 2006 | 09:13 AM
  #38
Nowhere Man
?? chuck
only if it has AC
Old Jan 4, 2006 | 09:32 AM
  #39
vp69435's Avatar
vp69435
Default Stamp image
I watched this car on Ebay. I think you bought yourself a real car, at a very good price. This looks like an original stamp to me. If it is isn't, it is without question the best 400 hp restamp I have ever seen. Emaiil me and I will explain.
Jim Jordan
President,
County Corvette
West Chester Pa
Old Jan 4, 2006 | 09:36 AM
  #40
ctjackster's Avatar
ctjackster
Jim Jordan
President,
County Corvette
West Chester Pa
Am I violating my New Year's resolution if I say I agree with Jim as to the great looking car and nothing obviously funny about the pad stamp?
