What is this called....
Old Jan 16, 2006 | 09:03 PM
64vettegal's Avatar
64vettegal
Default What is this called....
Took the body off Saturday and while removing all the shims I found two cushions that I need to replace. In front of the rear wheels on the frame gussets, there is a cushion about 2 1/2" tall and the diameter of Sweet Sixteen powdered donut. What is this called? I want to order the right thing.
Old Jan 16, 2006 | 09:18 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
This doesn't sound correct. You got a pic?
Old Jan 16, 2006 | 09:19 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
are you talking about the ruber bushings aboive the rear cross member of the axel
Old Jan 16, 2006 | 09:42 PM
64vettegal's Avatar
64vettegal
I'll take a picture tomorrow.
Old Jan 16, 2006 | 09:49 PM
64vettegal's Avatar
64vettegal
[QUOTE=NowUOTE]here Man]are you talking about the ruber bushings aboive the rear cross member of the axel[/Q
Maybe. I'm going to take a pic tomorrow. It was on a triangle piece of steel (gusset) that is right in front of the rear tires. The triangle piece of steel has a whole in it and is welded underneath the frame connecting the side and back of the frame. I'm thinking a body mount went there.
Old Jan 16, 2006 | 10:53 PM
78Vette-SA's Avatar
78Vette-SA
Maybe the Pinion Cushion mount right in front of the rear carrier in the center. Has two donut like cushions (upper and lower).
If you mean the two in front of the crossmember in the pic below, they are additional body mounts.
Old Jan 17, 2006 | 12:33 AM
SPLITRAY's Avatar
SPLITRAY
It almost sounds as though she is talking about the snubber on the underside of the kickup above the tires??? 2-1/2" high!!!
Old Jan 17, 2006 | 02:59 PM
64vettegal's Avatar
64vettegal
Default Here's a picture of what I'm looking for...
Here is where the rubber "cushion" was. Yes, I have a rust problem. I'm having it fixed.
Old Jan 17, 2006 | 04:16 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Body Mount
The 63/64 used that area for an extra body mount. Looks like there was a mount there at one time. It should be noted in your Assembly Manual. Some of the 63/64 guys should be able to verify this. Jerry
Old Jan 17, 2006 | 04:26 PM
78Vette-SA's Avatar
78Vette-SA
My guess would be Bubba welded that in to help support the rusted area. These are not present on 63's but perhaps the corner gusset was added for 64.
Old Jan 17, 2006 | 04:47 PM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
The corner gusset was added somewhere in the middle of the 64 model year. My early 64 does not have it, but it's in the AIM. I don't remember the release date. The standard suppliers have the correct cushion for this mount.
When ordering a body mount kit, make sure you specify all the mounts you have due to running engineering changes that took place during the year of manufacture.
Old Jan 17, 2006 | 07:25 PM
64vettegal's Avatar
64vettegal
Default Thanks
I've ordered an assembly manual. Thanks for all your help.
Old Jan 17, 2006 | 08:39 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
The corner gusset was added in April of '64 after this was found to be a weak area on the '63's. The correct gusset had a raised lip of about 3/4 inch on the inside edge so this is one bubba definately installed after the fact. There is a body cushion assembly available for this area for around $20. You can also buy the gussets if you want to keep them. Make sure you add it to your order if you intend to order a kit for the '63 because it won't come with it. My early '64 doesn't have the gussets and I've thought about installing them to cut down on the flex I experience at the door posts during "takeoff"...
Old Jan 18, 2006 | 08:03 AM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
If you look closely at the picture, you can see what is left of the raised lip on the ends of the gusset where it meets the frame and the crossmember.
Looks to be an original to me, but it should be replaced along with the rust repair.
Old Jan 18, 2006 | 10:43 AM
eddievette's Avatar
eddievette
St. Jude Donor '05-'06-'07-'08
It's original, I have a late 64. I can take pics. if you are interested.
Eddie
Old Jan 18, 2006 | 11:25 AM
67L36Driver's Avatar
67L36Driver
That is some serious rust damage. "Old Blue's" frame was not near that bad when I replaced it in '91.
Old Jan 18, 2006 | 07:37 PM
DansYellow66's Avatar
DansYellow66
An attempt to support a sagging floor pan maybe??? Were there any glued on rubber donuts on the crossmember towards the center (between the crossmenber and the floor of the crossmember) when you pulled it apart?
Old Jan 18, 2006 | 09:31 PM
64vettegal's Avatar
64vettegal
No. I didn't see any. I'm thinking about just putting rubber donuts there when I replace the gusset.
To What is this called....
