63 drum brake problem
Old Jan 25, 2006 | 08:08 AM
tk63vt's Avatar
tk63vt
Default 63 drum brake problem
I have a 63 vette with the original drum brakes all around. The previous owner replaced all the lines, steel and rubber, shoes, hardware, wheel cylinders, and I replaced the master cylinder. My problem is the left rear brake does not seem to fully release. The shoes do not seem to return fully to the pin at the top of the backing plate when the pedal is released. I thought there may be an obstruction in the line or wheel cylinder, so I removed the wheel cylinder and cleaned it out. I guess my next step would be to replace the wheel cylinder and see what that does. Any thoughts?
Old Jan 25, 2006 | 08:19 AM
Birdman63's Avatar
Birdman63
2021 C2 of the Year Finalist - Unmodified
A colapsed brake line could be the problem
Ant
Old Jan 25, 2006 | 08:51 AM
GCD1962's Avatar
GCD1962
Ant
That would affect both wheels then as there is only one rubber line at the rear. I would check the emergency brake, maybe the cable on that side is rusted up some preventing a full return
Old Jan 25, 2006 | 09:23 AM
Blk63Vette's Avatar
Blk63Vette
Hello
I had a similar problem and I replaced the emergency brake cables..I bought a correct from inline tube...installation not too bad now my emergency brake works pretty good...Plus no more dragging on the rear drum drivers side
Pete
Old Jan 25, 2006 | 09:49 AM
Procrastination Racing's Avatar
Maybe a solid axle 12 bolt under it?
If the IRS is still there, then there are two rubber lines, just like any other Corvette '63 to 82.
New hoses sometimes want to kink and not install like originals. It is possible that it is kinking and lets pressure in but not out. Or there could be a collapsed line or foreign material in the line.
Also, check the rub blocks on the backing plate. These are supposed to be greased so the shoe moves freely and be sure that the shoes rest on the backing plate, not bear into it.
Old Jan 25, 2006 | 10:47 AM
GCD1962's Avatar
GCD1962
Shows I don't know much about the '63s! But yes check the hose as they do separate inside, you can not detect this from the outside by looking at the hose - just replace it. The collapse starts slow with only a little drag, but I had one that eventually locked the brakes up tight
Old Jan 25, 2006 | 11:48 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Also make sure the return springs are installed in the correct location for each spring, the two springs ARE different. The gray spring is the primary, the black is the secondary.
Doug
Old Jan 25, 2006 | 03:39 PM
tk63vt's Avatar
tk63vt
Thanks for all the input. It's time to go home and see what the problem is.
Old Jan 26, 2006 | 09:20 AM
tk63vt's Avatar
tk63vt
Looks like it was a sticking emergency brake cable. Sometimes the easy things can be made so hard! Thanks again.
Old Jan 26, 2006 | 05:14 PM
GCD1962's Avatar
GCD1962
Glad I got part of it right. That is an easy fix for you
To 63 drum brake problem
