"RE-DISCOVERED HISTORICAL MARKING
Cruise-In III Veteran
I know this has been posted and I think it has to do with Job #. While I'm taking my dash apart I noted chalked on the driver's side support cross member (for the cowl) the following #: 9 1 5 2. Is this the Job # or body #? The body tag has A 3690 which is an AO Smith body; so, this must be the Job # right. Reading Noland Adam's book he says the Job # could have the same # assigned to both coupe and convertible.
Just curious.
Thanks!
Jim
Just curious.
Thanks!
Jim
I would be inclined to think it's might be something else
As far as I know, and have read about ( including Nolan's ) books, the job number never exceeds 500. Once that number is reached, they go back to # 1 and start over again. Here is where the Job number was found on one of my Corvettes during a restoration. The same # was also scribbled on outside of the rear bulkhead next to the fuel tank, and on the engine side of the passengers footwell.
Stepinwolf
Stepinwolf
also found this # on mine
Received 1,859 Likes
The 4-digit number on the face of the bar is the A.O. Smith job number; they used a different system, unrelated to any St. Louis numbers or the body number on the trim tag.
JohnZ,
Thanks for that insight! AO Smith Job #9 1 5 2 it is! I was reading in Noland Adam's book where the identical # could be on a coupe as they kept their job #ing separate. Interesting notation.
Jim
Jim
The first digit on mine is 8, does not show in photo..
