Holley carb baseline?
Does anyone know the best way to set up a rebuilt Holley 4bbl before putting it on the car? I know fuel bowl level can't be done but how 'bout mixture? Something like how many turns from all the way seated, etc. Any ideas you've successfully used would be a big help. Thanks!
Re: Holley carb baseline? (Lynndale)
Rule of thumb:
Lightly tighten air and fuel screws till they seat (lightly)
then back em' both out 1 1/2 turns.
Good chance you like it right there.
:seeya
:seeya
LYNN you can preset the float level.Pull the bowl body off of the carb and turn them upside down.Now adjust your float level so that you can insert a 7/16 drill bit between the float and the bowl body.That will get you pretty close for starters! :yesnod:
