Anybody Have A TRW Performance Book From The Late 60's/Early 70's
Does anyone have a copy of the TRW Performance Booklet that was put out in the late 60's/early 70's? I am looking for cam specs on the TP118 camshaft that was made for the small block Chevy. Thanks.
Cam Specs
P.S. We still sell 1/2 dozen these every year. It's a fairly big seller in the "restoration" end of the business, it has that "old familiar" sound. In a "small" unit it would be considered a "higher" rpm "stick". Probably in the basic range of 3200/7000 rpm. Hope this helps you!
CharlieW
I worked for TRW in the late 60s and I have a catalog dated 1969 titled TRW Racing and High Performance Parts. It lists the following information for cam TP118:
Chevrolet 1955-69 265-283-302-307-327-350
Mechanical lifters Drag and Track
Valve lift I & E 0.455"
Duration I & E 314 degrees
Overlap 86 degrees
Lash I & E 0.030"
Overlap 86 degrees
Lash I & E 0.030"
TRW cam TP-118
P.S.
As a point of interest I meant to list the prices for it also:
List price 35.09
Wholesale 26.32
Distributor 21.47
Confidential net price 16.84
Times have changed.
Charlie
List price 35.09
Wholesale 26.32
Distributor 21.47
Times have changed.
Charlie
I guess I don't have much experience in this group. My TRW catalog is from 1989, a new book in this group but it does offer the specs on your TP228
Big Block GM
Roller Camshaft
Net Lift 652/650 Duration 259/272 Overlap 86 degrees
Lobe Centers 108/108 set lash at .028/.030 Hot Rocker ratio 1.7
Big Block GM
Roller Camshaft
Big Block GM
Roller Camshaft
Big Block GM
Roller Camshaft
