62 vertical trunk support needed
Old Apr 27, 2006 | 05:26 AM
Mark Nevill's Avatar
Mark Nevill
Default 62 vertical trunk support needed
Has anyone got a fiberglass vertical trunk support. The one that is bonded to the rear inner wheel well and riveted at the top to the trunk lip.
I only need one, repro is OK.
Also need a rear outer bumper brace for a 62. Either side is OK or a pair.
Mark.
Old Apr 27, 2006 | 07:17 AM
The Corvette Kid's Avatar
The Corvette Kid
Default Trunk Support
Dr. Rebuild in Bridgeport CT. has a listing for the vertical trunk supports part #8200295 for $36.50.( www.DocRebuild.com 203-366-1332 ). Legendary Corvette Inc. in Warrington PA. also has a listing for the supports.(215-491-1717). Part #RDS-061. Corvette Central or Paragon should have the bumper bracket you are looking for . Good Luck. Bob
Old Apr 28, 2006 | 05:56 AM
Mark Nevill
Default Thanks
Bob,
Thank you for your reply. I tried Dr rebuild and it is no longer available. I will try the other sources you supplied.
Cheers,
Mark.
Old Apr 28, 2006 | 07:27 AM
The Corvette Kid
You could also try Paragon Vintage (800-882-4688 ). They are supposed to have a lot of used and NOS parts for early corvettes. Bob
Old Apr 29, 2006 | 06:52 AM
Mark Nevill
Default Thanks again
Bob,
Thanks again. I will give them a try as well.
Cheers,
Mark.
To 62 vertical trunk support needed
