Casting number information?
Where can I find out what these casting numbers go to?
Block # 3789935
Head # 3774692
Intake # 3739653
Trans. # 3885010
Thanks for any help!
Block # 3789935
Head # 3774692
Intake # 3739653
Trans. # 3885010
Block # 3789935 = 283-very late 1961 Corvette
Head # 3774692 = All 1960 Engines/1961- 230, 245 and 270 HP
Intake # 3739653 =1958-1961 Aluminum Dual 4-Bbl Carbs
Trans. # 3885010 = Can't help you with the trans.
Dave
Dave
Casting Numbers
Misfit -
The casting numbers you listed are as follows:
Block #3789935: 1961 (very late)
Head #3774692: All 1960, 1961 - 230, 245 & 270 HP
Intake #3739653: Aluminum: 1957 - 245 & 270 HP, 1958-1961 on dual 4bbl
Trans #3885010: Sorry, but I'm coming up empty on this number.
There are codes stamped on the transmission that will shed light on it.
The source for the above is the NCRS 1953-1972 Corvette Specification Guide.
Good Luck!
Good Luck!
M21
I think your trans # 3885010 is a M21 close ratio out of a 1967 vette.
Received 1,859 Likes
