C1 Coil problem?
Is there a quick method to see if my coil has gone bad? I went in to start my 58 this moring aand it wouldn't start. I have gas to the carburator and it just turns over, nothing. I pulled a plug wire off to check for spark by a plug, nothing. I pulled the coil wire out of the distributor and placed a screwdriver down in the top of the coil and had a friend turn it over with the coil wire next to it to see if a spark appeared, nothing.
Originally Posted by 67L36Driver
Points working? Coils don't go bad overnite.
I just went out and checked the point, they are fried. How does this happen, they are fairly new? I was working under the dash with the key on the on position, could this have done it?
Thanks Bill
Yep, leaving the key in the On position can fry the points. That is why the Accessory position was created, so radio, etc. can be used without sending energy through the ignition circuit.
I believe the way the points fry is for them to happen to be in the closed position when the key is left on.
Could this have fried the coil too? When I when to O'reilly's to get the points, I picked up a coil, after I replaced the points and sset the gap it still didn't want to fire. I then replaced the coil and it fired right up.
Thanks, Bill
I don't honestly know the answer to that one, sorry.
Glad you got it running again though.
I'm off to see if I can get my 65 back on the road today.
Points closed key left on points burn and coil, I've had two coils go out over the years while driving and each does a different thing when going out. Coils do burn out after time , that's why they sell them.
They can also short out, overheat and burst showering bystanders with hot oil. We had a foreman at work get his face badly burned. Safety glasses saved his eyesight.
Never 'hot wire' a coil except for a minute or two, the full twelve volts will fry it. Make your connection to the top side of the dropping resistor.
Thanks for validating what happened to me. I think I will keep a spare set of points and coil on hand.
