Sidepipes suck...
Subscribe
Sep 12, 2006 | 07:22 PM
Quote: You know, I just may give that a go this winter (give me something to do while the snow is flying here in MI). I have a set of 2" Stahl's, and am in the process of process of reworking my "under cover" spiral baffle setup.... i have access to the flow measuring equipment........and i have a set of factory sidepipes....hum)
That would be some very useful and inciteful information.
Duke
Reply 0
Sep 12, 2006 | 07:35 PM
Quote: I'm not sure if I should be worried or not....I have the Engine Analyser program too and have been modeling my engine for a few days, and have a pretty close model compared to the actual dyno numbers. Of course if I add a full exhuast system my power goes to crap. I have an undercar chambered exhaust, it is 2.5 inch expanding to around 3inch at the chambers but I think remains 2.5 inside diameter....no packing I can see, the chambers I think were made by Walker, but I am not sure now. I wonder how I can find out what these flow...my models say I will need about 750 cfm with 1000+ being even better.....I doubt they do the high end but it would be nice to get the 750. One question I have is as the pipes exit the car they neck down to 2.25....I can easily keep it at 2.5 if I want but I allowed the neck down on the idea that by the time the exhaust reached the back of the car it has cooled and slowed enough that the .25 reduction would give a little speed bump on exit helping the exhaust to get out away from the car and maybe even generate some extra flow....
Duke can you speculate on this exhaust? Without testing I am sure it is impossible to say anything for sure but just general ideas and would a cross pipe (I have no crossover in the intake) and or removing the final diameter reduction help my flow numbers?
Darren
If the minimum ID is 2.5" then a flow rating of 500 that I use for the OE 2.5" systems is probably in the ballpark, but if any projections into the flow stream reduce the diameter to under 2.5" that's the dimension you should use, then factor the flow by the area ratio. It's important to use the minimum ID. If you have a 4" pipe with one 2" restriction, it's going to flow like a 2" pipe! A corollary to "a chain is only as strong as it's weakest link" is "a duct will only flow as well as its minimum cross section."
A slightly smaller tailpipe diameter out of the muffler, especially if it's short is not a big deal due to exhaust cooling.
To get 750 CFM flow you're going to need 3" pipes and very low restriction mufflers with at least 2.5" internal passages, preferably straight through type like Dynomax Ultraflows or Magnaflows.
Duke
Reply 0
Sep 12, 2006 | 07:45 PM
Quote: That would be some very useful and inciteful information.
Duke
I'll see what I can do. And I agree 100% with your #20 post, (the others as well, of course).....you need to "Engineer" the complete package, or system, for a specific usage. I'll be doing some dyno stuff this winter and I'll pass on what I learn. I'm trying to design a balanced combination, that optimizes all the "stages" of the system, within a specific RPM range based on my intended usage, considering factors like chassis/tire limitation, gearing, etc.
On the factory sidepipes..... from what I gather (and I'm sure you know better than I), the race cars of the day had "loud side pipes", and someone in marketing said "make us some good looking loud sidepipes" for the production cars, and Engineering had little input. Hence, the C-2 "good looking loud sidepipes" that....well, flowed whatever they flowed.
Reply 0
Sep 12, 2006 | 07:54 PM
JohnZ has previously stated that the sidepipe option was driven by marketing, not engineering considerations.
Back in those days I think they designed the car and then added the exhaust system wherever it would fit, but the C2 was an exception.
The "holes in the frame" showed that the exhaust system was considered from the begining, and placing the mufflers at the extreme rear of the car was not only a good packaging solution, but improved exhaust system performance as well.
Duke
Reply 0
Sep 12, 2006 | 07:58 PM
dang I was afraid of that....I don't know that the pipes have any reduced diameter point but it is possible around bends etc. the internal diameter or the chambered sections seem to stay at 2.5. I wished I had done 3 inch at least back to the chambers...oh well this is was just a cheap an experimental pipe system for me, once I get it worked out I'll have it redone in stainless. Finding the right muffler is the trick...the off-roads would be perfect if they existed at some price that using them up didn't bankrupt me....I'm guess they flowed ok. I had hoped the bigger chambers would flow well. I will have to do some open vs closed tests and see what happens...Thinking some DynoMax next time...without the spare carrier I could maybe get an extra pair or something under the car....not sure how I would work the exits....wonder how loud those race mufflers would be.
Duke do you think Crossover Tubes really help especially at lower RPM? I haven't found how to get it represented in the Engine Analyzer, except by just guessing and adding some to the flow numbers...However I would expect that is not really real, since adding the crossover probably just allows you to get closer to the full flow potential, not really increase it....guess it depends on how the flow numbers are derived.
Reply 0
Sep 12, 2006 | 08:05 PM
for what it is worth I found this....
http://www.dynomax.com/news/Downloads/SEMA-Flowv2.doc
Reply 0
Sep 12, 2006 | 08:11 PM
Quote: ........Thinking some DynoMax next time...without the spare carrier I could maybe get an extra pair or something under the car....not sure how I would work the exits....wonder how loud those race mufflers would be.......
If you're working on an under-car system, you may want to review what this guy has done...... I've seen this car in action, it's not excessively loud, and it's faster than Stink!, and he's moving 511" @ 6500 RPM, or so, worth of air thru it.
(just put the address in your browser, and then remove the space in the word "document", i don't know why that space is there, but i can't get it removed lol )
http://www.fastraces.org/members/fastraces/fastraces.nsf/822dcaaaa26c6da985256dd80023623d/c10e85e88cc2ec19852571360045fb07!OpenDoc ument
Reply 0
Sep 12, 2006 | 08:17 PM
Quote: ....I think they designed the car and then added the exhaust system wherever it would fit, but the C2 was an exception..........Duke
and who ever worked up those 2.5" "Rams Horn" manifolds did some good work..... very compact, and efficent (as you've said numerous times).
Reply 0
Explore
Sep 13, 2006 | 05:50 AM
What was the air/fuel ratio between the side exhaust engine and the under car exhaust engine?
Reply 0
Sep 13, 2006 | 10:17 AM
Quote: Duke do you think Crossover Tubes really help especially at lower RPM? I haven't found how to get it represented in the Engine Analyzer, except by just guessing and adding some to the flow numbers...However I would expect that is not really real, since adding the crossover probably just allows you to get closer to the full flow potential, not really increase it....guess it depends on how the flow numbers are derived.
No way to model a crossover in EA that I know of. I believe it assumes two isolated systems on an eight cylinder engine. A crossover probably helps the torque curve at various points, but the effect is likely minor. The main purpose of a crossover is to soften the low frequency noise by allowing eight evenly spaced pulses on each side rather than four uneven pulses.
The human ear prefers higher frequencies.
If your current exhaust system model is causing high backpressure, spread out the LCA and see what happens. Exhaust backpressure will not be affected that much, but the torque curve should be improved if the effective overlap was over 4 sq-in-deg to begin with.
Duke
Reply 0
Sep 13, 2006 | 11:18 AM
Duke, one of my buddys even spoke of hooking a gauge in the exhaust to get a real world test of an exhaust system. Never though of side pipes on my body style. I have 2.25" back until the Exit of the mufflers. It was as much as the muffler shop guy wanted to tangle with. Still have to adjust a hanger every now and then.
Reply 0
Sep 13, 2006 | 01:25 PM
A gage would provide some good info. One could drill and tab an old heat riser and plumb in at that point pretty easily.
Reply 0
Sep 13, 2006 | 01:49 PM
  #33
Quote:
but until customers start demanding real engineering data, they'll continue to get sold a bill of goods based on "look", "sound", and all sorts of other marketing foo-foo.
Duke, I understand how jaded you can get with the aftermarket. I am so frustrated trying to hot rod my car in a sensible manner. How hard can it be to flow a #$%@^ muffler???????? This data should be as available as the muffler case size.
Here's a Vizard article on developing a muffler system with minimal impact on performance. I thought it had some good points:
http://www.popularhotrodding.com/eng...exh/index.html
Reply 0
Sep 13, 2006 | 04:05 PM
  #34
Quote: If the minimum ID is 2.5" then a flow rating of 500 that I use for the OE 2.5" systems is probably in the ballpark, but if any projections into the flow stream reduce the diameter to under 2.5" that's the dimension you should use, then factor the flow by the area ratio. It's important to use the minimum ID. If you have a 4" pipe with one 2" restriction, it's going to flow like a 2" pipe! A corollary to "a chain is only as strong as it's weakest link" is "a duct will only flow as well as its minimum cross section."
........Duke
I've agreed with most of your statements in this thread except this one. The example you gave of "If you have a 4" pipe with one 2" restriction, it's going to flow like a 2" pipe" is inaccurate. It will actually flow somewhere in between depending on the transition to and from the restriction, where the restriction is located, how long the rstriction is, etc.
I guess it boils down to what you're trying to represent with that statement. If you're attempting to make general recommendations concerning good design, then yes, if you're trying to put empherical data to a design, and be reasonably accurate, then no.
The rest is good information.
Reply 0
Sep 13, 2006 | 04:17 PM
  #35
Quote: I was recently contacted by a '65 L-76 owner who felt his 225 RWHP @5500 was low, and I agreed. His engine is configured very similar to Mark Johnson's engine, which measured 278@6500, so 225 represents a nearly 20 percent reduction.
A series of compression and leakdown tests indicated more variation than one would expect for a relatively fresh engine, and one cylinder definitely appears to be a little weak, but not enough to drop peak power 20 percent. Peak torque of 270 was good - a little better than Mark's 263, but Mark's fan was probably consuming 15 lb-ft, and the other owner reported that the fan clutch probably did not tighten during the tests.
There was one major "external" difference. The car in question has OE sidepipes and Mark's car has the under-the-car system.
So I decided to see if I could come up with a flow model for the sidepipe system and analyze what effect it has on backpressure and power output.
The Engine Analyzer simulation program allows the user to model exhaust systems by stating flow rate at 1.5" Hg (20.4" H2O) depression, which is the same depression used to rate four barrel carburetors. Using some engineering intuition I came up with a model of 250 CFM per side, 500 total, and this jibes with test data. For example, Mark's 278 RWHP converts to 327 SAE net at the flywheel using 15 percent driveline loss, and EA's prediction is 324 so they correlate within one percent.
Using some good verbal descriptions of the OE sidepipe system I modeled it as a 1 3/4" pipe, which is probably giving it the benefit of the doubt, and the flow ratio at constant depression is proportional to the area ratios, which is a function of the square of the diameters ratio, which is 0.49.
In other words, one side of the under-the-car system flows as much as two sidepipes. Imagine a SHP engine with a single exhaust system!
Plugging 245 CFM total exhaust flow into EA increases exhaust backpressue on Mark's engine at 7000 revs from 3.3 to 9.5 psi - nearly triple- dropped peak power ten percent, and knocked 500 revs off the useable power bandwidth, reducing the upper boundary from 7000-7200 to no more than 6500.
It's still not enough to account for 20 percent loss, but I'd be willing to believe that the sidepipes account for 15 percent loss and the slightly weak cylinder 5 percent, and this is supported by the peak torque data.
It's always been "heard on the street" that sidepipes are more restrictive than the under-the-car-system, but until now I had no quantification. Now I know, or at least have a pretty good idea.
If you want sidepipes and high peak power - forget it, they are mutually exclusive. I always felt that the under-the-car system was good. It may not be a wonder to behold visually, but it was very well engineered and works very well. Limiting backpressure to only about 3 psi with modest sound level is indicative of good engineering. Large free flowing manifolds, generous pipe sizing, and mufflers located as far back as possible is a textbook description of a good exhaust system. Now if someone could only do an accurate reproduction of the OE off-road mufflers, so we could have that great sound...
Though the under-the-car-exhaust is very efficient on a SHP small block, it's going to be restrictive on a SHP big block generating about 5.5 psi. Backpressure increases with the square of exhaust mass flow, so the sidepipe model yields about 16 psi backpressure on a SHP big block, which places exhaust backpressure in the range of seventies vintage Corvettes with the single bead bed converter, and your big block may be lunch for Mark's small block.
The other bit of insight is that if your exhaust system flows 80 percent or better (at 1.5" Hg. depression) of what a properly sized carburetor flows, then you've got a good system. So 500 CFM is good for a SB, but a high revving BB needs 700 CFM - 3" pipes, bigger mufflers... sorry, there's no room! My model for the C6/Z06 is 750 CFM.
It would not be that hard to test a complete exhaust system - one side from head pipe to tail pipe - on any flow bench that is suitable for testing cylinder head flow, but until customers start demanding real engineering data, they'll continue to get sold a bill of goods based on "look", "sound", and all sorts of other marketing foo-foo.
Duke
What you need is LARGER FLOWPATHS!!! The OE & reproductions do not address this vital issue.
Check this out: http://www.classicchambered.com/clas...rformance.html
Since I don't know hot to attach a file here, someone want to volunteer to post a pic. for me? PM me with your E-mail.
Reply 0
Sep 13, 2006 | 04:48 PM
  #36
Pay close attention to figure #9 in the article, and the accompanying text that addresses expansion chambers.
I believe that is the only thing that could have boosted my torque appreciably in certain RPM ranges.
Doug
Reply 0
Sep 13, 2006 | 05:01 PM
  #37
Duke,
I've read some articles on extending the collector for added
power gains... so, I must admit I was a little surprised by your
findings.... Have you studied collector length in relation to power and
.. would it be safe to asume that an extended collector exhaust
with traditional high performance pipes/mufflers aft of it is different
than just plain sidepipes??? apples and oranges???
Kyle
Edit- this would obviously be in a stituation where headers were used
Reply 0
Sep 13, 2006 | 06:15 PM
  #38
Kyle
In the early/mid '60s many of the NHRA stock class record holders all used Stahl Headers. For a relatively short period of time "Stahl's" theory was that longer collectors added more power. The cars with his headers ranging from I/Stock up to FX (Chev Z-11's) had the headers exit the front fenderwell and then had a collector the full length of the rockers back to the front of the rear wheels. They all sounded kind of funny with this set up. It wasn't too long before Jere's next theory cut the length of the collector to about 1-2" from the front wheel well.
Reply 0
Sep 13, 2006 | 06:56 PM
  #39
http://www.popularhotrodding.com/eng...exh/index.html[/QUOTE]
What a great article. Two points are really important: one you can build a tuned header system and get the benefit of it's tuning as long as you have an expansion box (plenum) or some such (why would the wave care if it's reflected from an expansion into a 14.7 psi space or a 16.7 psi space) and (I'm not sure he covered this) mufflers don't like to be pulsed, they want to be steady state flowed. A plenum in the exhaust helps to approach this. Gee given appropriate design even a stock motor might benefit form headers.
Reply 0
Subscribe
