Alternator conversion
Old Dec 15, 2006 | 01:58 PM
fredetl's Avatar
fredetl
Default Alternator conversion
I want to convert my 58' from the generator to an alternator. Can someone tell me what alternator will fit the original bracket? If none are a bolt on replacement, what bracket should I look for. I plan on adding A/C and possibly electric windows later on so it needs to be one of the larger output models. Any advice would be appreciated.
Old Dec 15, 2006 | 04:40 PM
knight37128's Avatar
knight37128
There is no alternator that bolts up with the generator brackets.
Mr Gasket sold a chrome bracket that bolts to the exhaust manifold for the alternator conversion. At least they did 15 years ago.
You may want to check with the "hot-rod" places.
Old Dec 15, 2006 | 04:48 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
depending on your exhaust manifold mounting ear configuration, i suggest you look at the alternator brackets for a C2.
Bill
Old Dec 15, 2006 | 04:50 PM
my58's Avatar
my58
Alan grove makes a great bracket to do what you desire
http://www.alangrovecomponents.com/
search the forum for lots more on this subject.
The brackets are discussed in this topic on AC
http://forums.corvetteforum.com/show...ght=alan+grove
Old Dec 15, 2006 | 06:11 PM
knight37128
http://store.summitracing.com/partde...5&autoview=sku
$ 6.95 at Summit
Old Dec 15, 2006 | 08:07 PM
LabRat's Avatar
LabRat
https://www.corvetteforum.com/techti...D=73&TopicID=4
Old Dec 15, 2006 | 08:41 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Unless you just like the work, the original generator will do just fine.
Old Dec 15, 2006 | 10:51 PM
67L36Driver's Avatar
67L36Driver
Yes and No.
I'm changing my '62 Corvair to an alternator for several reasons. One is to get a more rapid charge on the battery due to the short hops I normally take in it. Another reason is to get rid of the mechanical contacts that can stick on a regulator. Have you ever boiled a battery dry? Also, I think the alternator is half the weight of the generator.
To Alternator conversion
