C-2 Distributor Identification
Old Jan 10, 2007 | 07:38 PM
Kensmith's Avatar
Kensmith
Default C-2 Distributor Identification
Other than a removable tag, how can you tell if you have the correct distributor? Any codes, numbers, configuration you can visually see to tell the difference? I want a correct 1965 Distributor but I know people collect tags and I don't know it they just tag one that looks correct then sell it for more money. I found one with a correct tag but before I spend the almost $300.00 for it I want to make sure I am not just paying for the tag. Help please!
Old Jan 10, 2007 | 08:08 PM
MikeM's Avatar
MikeM
The only way I know to do it is to put it on a distributor machine and check the mechanical and vacuum curve or put it in your engine, using a dial back light and vacuum pump. Then compare the readings with the specs in the '65 shop manual. You may find your results are not found in "any" manual.
Any shop that has the distributor machine could match it pretty close to the appropriate '65 specs or you could do it yourself.
Old Jan 10, 2007 | 08:23 PM
Kensmith's Avatar
Kensmith
Mike,
So the distributors are all basically identical other than the way they are set-up? I could pay for the 65 date correct per the tag, but the tag could be on a 64 set up for the same 327/365 motor as mine? If so, you are basically buying a tag?
Thanks,
Ken
Old Jan 10, 2007 | 08:41 PM
knight37128's Avatar
knight37128
The tag is not that much.
Old Jan 10, 2007 | 08:47 PM
Kensmith's Avatar
Kensmith
You got one for less?
Old Jan 10, 2007 | 08:53 PM
knight37128
$27.05 at Corvette Central
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
Old Jan 10, 2007 | 09:04 PM
Kensmith's Avatar
Kensmith
Ok, so are we saying the distributor is the same for C-2 other than the curve or setup? And all you need is a tag to show what set-up you have?
Old Jan 10, 2007 | 09:12 PM
knight37128
Yep
Old Jan 10, 2007 | 09:23 PM
Kensmith's Avatar
Kensmith
Yep
That's what I thought you were saying. Geez, I keep learning stuff and someday I'll be kinda knowledgeable. Or not!
Thanks!
Old Jan 10, 2007 | 09:45 PM
Kensmith's Avatar
Kensmith
Troy,
Thanks for the info. Ordered the correct tag. $35.00 delivered from Corvette Central. That saves me over $200.00. Great advice again from a forum member.
Old Jan 10, 2007 | 09:49 PM
knight37128
Glad I could help.
Old Jan 11, 2007 | 09:20 AM
MikeM's Avatar
MikeM
Virtually everything inside the bare housing is different for a SHP engine as opposed to the base or even optional engine. After you get your new tag installed, find out what advance characteristics that distributor has. You could have problems from sluggish running or surging to pre-ignition unless you know what you have and how to correct it.
Old Jan 11, 2007 | 10:56 AM
Kensmith's Avatar
Kensmith
The distributor I have is set up for a 350hp motor. Will have it checked when I have the spare correct 365hp motor re-built to make sure it all works together. Thanks!
Old Jan 11, 2007 | 11:02 AM
Tom454's Avatar
Tom454
There are differences in the castings as well.
I just rebuilt a BB distributor and laid it on the table next to a SB unit. The oil holes are in a different location.... and there are a few other small casting differences, not necessarily BB vs SB... just differences in general.
Old Jan 11, 2007 | 06:31 PM
Kensmith's Avatar
Kensmith
Any thought on how I would go about checking it out? Maybe someone knows the difference and has photos or photo of a correct 1965 327/365 non-transistor distributor?
Old Jan 12, 2007 | 11:45 AM
MikeM's Avatar
MikeM
I'm thinking there might be a casting difference in the housing down by the gear in the oil passage on some years. BB vs SB. I really don't remember but as far as I know, both are interchangable. I don't think there are any casting differences above the manifold. Maybe Tom has a picture for clarification?
Old Jan 12, 2007 | 01:38 PM
JohnZ's Avatar
JohnZ
Here's a '67 points distributor - for all practical purposes, they're all the same from '63-'74 except for calibration items - weights, springs, autocam, and vacuum advance unit; the particular combination of calibration items determines the part number for the finished assembly. Just get it set up to the correct original specs, order the aluminum part number/date tag you need, and you're all set. Nobody will EVER know what it came out of - they're all the same.
To C-2 Distributor Identification
Old Jan 12, 2007 | 02:09 PM
Kensmith's Avatar
Kensmith
Thanks John, wish mine looked that nice. Maybe I will clean it up!
Old Jan 12, 2007 | 03:14 PM
Tom454's Avatar
Tom454
If your email address is available... I'll send you pictures of a BB 67 and a SB 66 side by side.... and you will clearly see that they are not identical.
Edit... re-reading the posts.... I think y'all may be correct that they are indistinguishable above the manifold... the only differences I am sure of are below the manifold.
Functionally.... yup. Visually, nope.
Old Jan 12, 2007 | 03:20 PM
knight37128
Why not post here. I would like to see the difference.
