1965 corvette convertible - attempting to put on new dash skins - removed instrument cluster, glove box, radio. have removed metal trim by windshield. Question 1 - Would it be easier to take the bolts out next to windshield and remove the pop rivets on each side where door closes and remove the complete dash? Question 2 - How do I remove the dash pad clips? Do the speakers and clock have to be removed first before removing dash? Any suggestions or comments would be greatly appreciated. Thanks, fellows!!!! Bobby
To get those pads off for reskinning, you do not have to remove the clock or radio. The pads are held to the fiberglas dash structure by 28 goofy clips, 14 on each pad. Using the flat blade of a screwdriver, insert the blade inside the clip as you see it and twist. These goofy clips will collapse on the other side when you do this. I didn't break any when I did this but figured the clip was weakened and replaced 'em all (north side of $50.00 for the set).
Wait a minute. I stand corrected. Having the clock and radio out enables you to get at those clips that are on the inside where the pad narrows and flows down to the console.
Here's my archived successful attempt at skiinning mine:
If you plan to paint the fiberglass portion of the dash it might be easier to remove the entire dash. It's bonded with adhesive at the center trans tunnel, but you can cut through it with a putty knife and a hammer. The clips are kind of a a reverse-logic deal. To loosen them insert a small screwdriver inbetween the two tabs or legs and pry them apart. Once they are about 3/16 inch apart they should be loose and can be wiggled out. Plan on some of them breaking and having to be replaced - so order a dozen or so. The ones on the sides near the radio are the hardest to reach and work with. To reattach, insert and squeeze the two legs together with pliers. If you remove the dash I would remove the clock as the bezels have a habit of coming loose and falling off at the worse moment.
Dash pad clips are removed by putting something like a screwdriver tip into them and spreading them open. Spreading the outside closes the clip in the inside of the pad area so they can be pulled out.
The clock is easy to remove by popping off the clip that is on the pin on each side of the clock. You can get to it when the glovebox is out. The clock comes out the front.
To get to all the pad clips you'll have to remove the radio as well. The speaker can stay if you're removing the pads only.
Some guys on the forum have found that removing the whole dash is the easiest way to go since some of the pad clips are hard to get to. You'll have to decide on that but since the pads have to be removed to reskin them, I'd give removing them a try first. You'll probably break some of the pad clips when you remove them so plan on replacing some....I think there's 28 and they're about $2 each. Good Luck with your project.
Remove your dash, you'll be glad you did. I have mine out right now and believe me you won't be able to get some of those clips out because they are just inaccessible otherwise. You will also find other things to take care of when you get that dash out too!
