Well I have installed a 383 stroker in my 64. Its definitely not the Sunday cruiser it was with the base 250 ph. The stroker is suppose to be very well balanced. It sure seams to have to much vibration to me. I'm no expert on how much is to much. Does anyone know how this can be checked. Or where I could take it in the Dallas, TX area.
Your damper should be a 400 style with the offset weight installed they bolt on the back side. Did the machine shop have your damper when they balanced the rotating assembly?
The damnper may be your problem. I don't know anything about the one you used. Your engine should not vibrate at all assuming it was balanced properly (clutch too).
Is the vibration a shake or more of a buzz? What rpm brings it on? In gear, out? Road speed?
I don't know how knowledgable you are so I'll ask if you're not confusing the expected rough idle of a hot rod aftermarket cam with a vibration?
I have a SFI approved small diameter dampener, and a externally balanced flywheel
Small diameter balancers seem to have this problem on the 3 3/4 and longer stroke stuff. Verify that it's actually a harmonic (it'll do it in neutral) and if it is go buy yourself an eight inch fluidamper.
I don't know how knowledgeable you are so I'll ask if you're not confusing the expected rough idle of a hot rod aftermarket cam with a vibration?
Need some more info.
I'll be the first to admit, I don't know enough about it to determine if its acceptable. Its definitely a shake, Its bad enough you cant make things out in the mirrors. Its not the cam, it does do it in neutral, I used poly motor mounts. Could that be part of it? It seems to be worse at lower RPM and 1st and 2nd. thanks for the feed back.
Thats a good question, I'm not sure. This 383 came out of a C3 that he had ran for about 2,000 miles.
I've never used poly motor mounts. I have used solid steel mounts and they'll transmit a lot to the frame. Probably not what you're experiencing if you can't see out of the mirrors. That's pretty violent.
I don't think the small harmonic balancer would cause that unless it was for an internal balanced engine. Your shake sounds like it is the wrong (internal balance) flywheel.
How did it run in the car it came out of? There is the possibility here that the engine has been balanced internally and you used external balanced balancer and flywheel.
To check the balancer get under the car and look at it from the back side if it has a depression 3/4 around or a plate bolted on it's the right one. If theres a even pocket all the way around with no weight it's not right for your engine.
After reading the ad and looking at the engine, I highly suspect what I suspected first: a combination of poly motor mounts and the camshaft that's in the engine. Not enough vacuum to shut the headlights??????
Does it smooth out the faster you run it?
Have you contacted the seller with your concerns or are you waiting for external opinions before you do?
That's another problem I'm working through,
I do have a problem with crank case pressure it wants to push oil out anywhere it can. (low vacuum)
It seems to smooth out at faster speeds.
Contacting the seller at this point wouldn't do much good. He has been very helpful but I bought the motor as is.
"Contacting the seller at this point wouldn't do much good. He has been very helpful but I bought the motor as is."
The seller could tell you if the engine had a vibration.
I see a breather in each valve cover vented to atmosphere. Is that what you have? Guaranteed to blow oil out. Get a vacuum hookup on one valve cover and pull air from the other side or some means of controlling the crankcase pressure.
I don't know what effect gapless rings have on blowby. Maybe one of the racers knows.
To answer your question, I cannot recommend anyone in Dallas. Too far away. I'd think if you showed up at a cruise in your neighborhood or anywhere there's a gathering of car guys, you'd likely run across someone who could help you first hand.
I don't want to sound stupid but I don't know. I didn't change the spark plug wires nor did I remove the distributor. I can double check and make sure one of the plug wires didn't get plugged in wrong.
You won't know what to check if you don't know what cam is in it. Lunati can verify for you. Another short way to check is look at the plugs and see if any of them are fouled and expecially #'s 4 and 7.
