dash capacitors
Old Feb 25, 2007 | 09:54 AM
lrj975's Avatar
lrj975
Default dash capacitors
Capacitors behind dash all look original. Do I need to test if they are still good? Are these regularly replaced or leave it? The only purpose to reduce static on radio reception?
Old Feb 25, 2007 | 11:23 AM
JohnZ's Avatar
JohnZ
There's no way to test them at home, and you probably couldn't tell the difference anyway; they're for radio noise suppression. I'd just leave them alone, and be glad you still have them.
Old Feb 27, 2007 | 02:44 PM
1COOL60's Avatar
1COOL60
From: Emporia, pay no attention to that man behind the curtain, KS
Capacitors do deteriorate over time; the dielectric breaks down. If you use your radio frequently, replacing them will help eliminate interference. If you aren't too concerned with the performance of the radio, don't worry about them.
To dash capacitors
