Voltage Regulator
Old May 8, 2007 | 10:06 AM
BrettG's Avatar
BrettG
Default Voltage Regulator
Have recently reinstalled the intake, radiator, carb, hoses, engine harness with new TI harness, TI module, etc.
Had a smile ear to ear when the car started!! (first time undertaking a project of this nature)
Is it normal for the voltage regulator to make a clicking sound when the battery cables are connected / disconnected?
Old May 8, 2007 | 02:36 PM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
Did you polarize the regulator?
Old May 8, 2007 | 02:51 PM
BrettG's Avatar
BrettG
No.
I had no idea that the regulator must be polarized.
Pls. enlighten me...
Old May 8, 2007 | 04:18 PM
BrettG's Avatar
BrettG
Default Polarize Regulator? - 65BB Coupe
Pls. review initial post for details.
Hedgehead indicated that I may need to polarize the regulator - is this necessary for this vehicle?
I did some preliminary research & have found conflicting answers.
Gauge seems to read correct, although I have not connected a meter to the battery terminals to verify all is well when the car is running.
Old May 8, 2007 | 04:20 PM
ctjackster's Avatar
ctjackster
mmm, as near as I know GENERATORS need to be polarized, but not ALTERNATORS. As for voltage regulators, they do not need to be polarized as they are not polarity sensitive. Folks are sometimes told to polarize the voltage regulator to actually polarize the generator, not the regulator itself.
flame suit on
Old May 8, 2007 | 05:25 PM
Old Blazer's Avatar
Old Blazer
Your good to go.
Old May 8, 2007 | 05:29 PM
BrettG's Avatar
BrettG
ahh, concise / accurate infomation - much appreciated!
Now to figure out that noise when the battery cables are connected / disconnected........
Old May 8, 2007 | 05:45 PM
ctjackster's Avatar
ctjackster
the VR has a relay of sorts - "points" and that is the noise you are hearing (they are opening and closing). I eventually ditched mine for a Wells VR 715 solid state VR, and it works flawlessly and looks close enough to the orginal.
Old May 8, 2007 | 06:21 PM
skids's Avatar
skids
Old May 8, 2007 | 11:03 PM
67L36Driver's Avatar
67L36Driver
Drill out the rivits holding the cover on and put on the cover from your original regulator to please the 'nit pickers'.
Old May 18, 2007 | 09:38 AM
Shu68's Avatar
Shu68
Default Solid State vs Relay Voltage Regulator
I have a '68 with the mechanical relay voltage regulator. I have changed out the battery, alternator, voltage regulator, and ohmed all the wires, still have charging issues. Disconnected the "R" and "F" leads to the Alternator, jumpered the "F" lead to the BAT out on the alternator and got the desire 13.8 volts at the battery. This tells me the the Alternator is good, and possible the "new" VR is bad. After reading this thread, it would seem that the Solid State Wells VR 715, once replaced (on order), will eliminate the VR being the culprit? Yes/no? Thoughts?
Thanks,
Shu
Old May 18, 2007 | 09:42 AM
magicv8's Avatar
magicv8
I vote yes
Old May 18, 2007 | 09:54 AM
ffas23's Avatar
ffas23
Thanks,
Shu
Make sure you have a good ground to the regulator. I have seen electronic regulators go bad from not being grounded properly being in the auto parts business. I have also seen people burn out a new regulator by just unplugging the old one and plugging the new one in to just test it without mounting it or using a test lead to ground.
I usually just hook up my Milton #1260 Battery and load tester up to the battery while the vehicle is running to check for a bad regulator or alternator. Tells me right away.
Old May 18, 2007 | 10:08 AM
Shu68's Avatar
Shu68
Default VR Grounded
Thanks...I was told that at the store when I bought it, to make sure is was grounded, and it is.....Just driving me crazy not being able to find the problem...but we will see if the solid state one makes a differnece. Thanks for the quick reply.
Shu
Old May 18, 2007 | 10:41 AM
67L36Driver
Shu68:
Your profile does not indicate where you are located but if in or near a medium or larger city you can take your regulator to a starter and generator shop and have it checked. Most of the chain parts stores also offer this service. Check the yellow pages.
Old May 18, 2007 | 12:16 PM
Dicecal's Avatar
Dicecal
Thanks,
Shu
YES ! Or you can check and/or adust the voltage output from the old manual VR. I went the wells VR715 route. Just went thru that mess myself!!!!!!
Old May 29, 2007 | 02:56 PM
Shu68's Avatar
Shu68
Default VR Works!
****UPDATE*****
It is charging now! Yippee!
Thanks everyone for all the help and advice!
Shu
To Voltage Regulator
Old May 29, 2007 | 03:07 PM
Paul L's Avatar
Paul L
Was the Wells VR-715 the solution?
Old May 29, 2007 | 03:12 PM
BrettG's Avatar
BrettG
Jury is still out with regards to my problem. Send the Alt. back to the seller & had it checked. Seller indicated there were no issues.
I have yet to reinstall it, but have secured another VR715.
Old May 29, 2007 | 03:14 PM
MasterDave's Avatar
MasterDave
Moderator
Take the darn thing off and install a solid state regulator. Same hookups, looks fine. No problems with charging since I installed mine, about 2 years now. The best part is that they're only $9.95 from just about anywhere. I got mine from JC Whitney.
