Voltage Regulator
Old May 29, 2007 | 03:22 PM
BrettG's Avatar
BrettG
Originally Posted by MasterDave
Take the darn thing off and install a solid state regulator. Same hookups, looks fine. No problems with charging since I installed mine, about 2 years now. The best part is that they're only $9.95 from just about anywhere. I got mine from JC Whitney.
Have already puchased & installed a Wells VR715 - with no change.
Sent the alternator out to be checked and purchased another VR715 - have yet to drop either in the car.
Old May 29, 2007 | 04:57 PM
Paul L's Avatar
Paul L
OK, I'm confused. What did you do to correct the problem?
Old May 29, 2007 | 05:09 PM
Shu68's Avatar
Shu68
Default Wells VR715
Paul67,
Yes it was the Wells VR715, had to order it from Autozone, every store around me was out of stock.
Shu
Old May 29, 2007 | 08:28 PM
plaidside's Avatar
plaidside
BrettG, If your regulator clicks when you install the battery terminals you have a problem. Weather you put a mechanical or electronic regulator on it will not solve it.
Either you have a bad diode in the alternator which is leaking back through the white wire to the regulator or the wires are incorrectly placed on the regualtor.
Please read this article I wrote. It should help you with your diagnosis.
Here is a basic explanation of how an alternator/regulator works:
When you start the engine a voltage is sent to the number ‘4’ terminal of the regulator, then it goes through the regulator, out the blue wire to the ‘F’ terminal of the alternator.
This energizes the field of the rotor and creates a spinning magnetic field inside the stator windings of the alternator. This starts the charging cycle. Now a small amount of voltage is sent back out the ‘R’ terminal of the alternator (white wire) to the number ‘2’ terminal of the regulator. This closes a set of points and allows the battery voltage from the red/orange wire to power the field circuit. If you had an idiot light it would now turn off. The amount of field current depends on the electrical load that is placed on the system. Now that the stator is producing current it will maintain the battery and take care of all the loads that are put on the electrical system.
Remember the battery is there to start the car and add current to the system only when the alternator is not producing enough to cover the electrical loads.
So if you have 37 amp alternator and you have 40 amps of electrical loads, then 3 amps will be supplied from the battery. This means the alternator has no current left to charge the battery and the voltage reading across the battery will be below 12.66v.
A properly working system should maintain a battery voltage of approximately 13.8-14.8 volts depending on temperature.
Always check charging volts with a fully charged battery and engine above 1000 RPM.
If the battery is very low when tested, then the charging voltage will be low. As the battery begins to charge then the charging voltage will rise.
A fully charged battery, after any surface charge is removed, will read 12.66v.
Alternator/ regulator testing:
First, check for battery voltage at the stud where the large red or orange wire connects to the alternator. You should have battery volts. If not, repair the wire or circuit.
Then disconnect the plugs from the regulator and alternator.
Check the continuity of the blue (field) and the white (relay) wires between the plugs.
Repair any wire if they do not have continuity.
Reinstall the alternator plug and leave the regulator plug disconnected.
With a voltmeter, check voltage at the number 3 terminal on the regulator plug, it should read battery voltage. There should not be any voltage at the other three terminals at this time.
If you have voltage at the number 2 terminal, R on the alternator, you have a leaky diode in the alternator, replace the alternator. This will cause a battery drain and the regulator with be hot to the touch with the key off.
Now turn the key on, you should have voltage at the number 4 terminal, this wire comes from the fuse panel. If you had an “idiot light”, this would be from the bulb.
This is what is called the exciter circuit, without voltage to this terminal the charging system will not begin to charge.
If no faults were found so far, leave the regulator plug disconnected, make sure all wires are clear of the fan and start the engine.
With a voltmeter connected to the battery and the RPM at approximately 1000-1200, jump from the ‘F’ terminal of the regulator plug to the ‘3’ (orange or red wire) terminal.
You should see an increase in voltage at the battery and hear the alternator working. If you hear a growling noise from the alternator you have either a bad diode or a bad stator winding.
Don’t leave the jumper connected too long because you don’t want the voltage to go over 15 volts for an extended period of time.
If you don’t see the voltage go above battery voltage after a few seconds then you have a bad alternator.
If the voltage rose quickly and then decreased this means you have a slipping fan belt.
Now connect a voltmeter to the number ‘2’ terminal (white wire) of the regulator connector and again momentarily jump from ‘F’ to 3. You should see about 8-10 volts.
If not, you have a bad diode in the alternator.
If all is OK up to this point reconnect the regulator connector.
If it is still not charging, run a separate ground wire from a good ground to the base of the regulator. Now if no there is still not charging, replace the regulator.
If you have an overcharging condition, it is either a bad ground at the regulator base or a bad regulator.
This is the basic testing procedure that I have been using for many years. There are other possible problems that can cause a no charge condition but they are rare and harder to diagnose.
Any questions or comments you can email me.
Joe
Old May 29, 2007 | 11:01 PM
BrettG's Avatar
BrettG
Joe
Joe,
I appreciate the detailed post regarding the proper function as well as tests for the charging system. I will be traveling in the near future & have limited time to spend troubleshooting but will do my best to figure this out ASAP.
Last week I had sent the newly acquired alternator back to the seller, he had it tested by his people & confirmed it was 100% operational. Haven't had time to reinstall.
Old May 30, 2007 | 02:14 AM
rene-paul's Avatar
rene-paul
Excellent post Joe!
brgds
rene
Old May 30, 2007 | 07:23 AM
Paul L's Avatar
Paul L
Joe,
You have just enriched my library. Thanks!
Old May 30, 2007 | 09:27 PM
plaidside's Avatar
plaidside
BrettG
When you install the alternator do not connect the two wire plug on the back, only the hot wire. Connect the regulator plug.
Now connect the battery. See if the regulator clicks.
If not now plug in the two wire plug. If it clicks now you have a leaky diode in the alternator. The alternator will check out OK on a test bench.
Old Jun 7, 2007 | 05:13 PM
willy p's Avatar
willy p
7th Gear
Default Wells Voltage regulator 715
I need information on where to purchase the wells VR 715. Thanks. ***** p.
Old Jun 7, 2007 | 06:36 PM
ffas23's Avatar
ffas23
*****, The electronic regulator equal to the D635 Delco can be purchased from most part stores everywhere. You don't have to get a Wells VR715. Most of these electronic regulators are made by the same people believe it or not. Here's a list of manufacturers and their equivalent part number for the Delco D635/VR715 Wells.
Standard Ignition VR103
Borg/Warner R281
Neihoff DR153B
Echlin VR142
Filko VRD459
KEM KVR172
GP VR273
Wells VR715
Old Jun 9, 2007 | 01:41 PM
tuxedo's Avatar
tuxedo
Just put a solid state regulator on the car. Got rid of the point regulator once and for all.
Old Jan 10, 2009 | 05:42 PM
Shu68's Avatar
Shu68
Originally Posted by paul 74
Was the Wells VR-715 the solution?
Yes it was, over a year now and not problem with charging or regulating the voltages. But looks like I will need to update the Distributor to an HEI unit, but that's another thread...
Old Jan 10, 2009 | 09:03 PM
  #33
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Got mine at the local Autozone. Dave
