Vibration help - moved from Hurst thread
Old May 20, 2007 | 06:16 PM
magicv8's Avatar
magicv8
Default Vibration help - moved from Hurst thread
Originally Posted by blubu
I have the same problem with a vibration?? I too have had all shafts balanced as well as rear end new brgs evrywhere whls and tires balanced. To no avail. When you lean on car. she will shudder from the rear. I have no idea where it comes from. Tulsa driveline specialist has checked it and rechecked it. You can put car on stands in the rear and unload suspension. Vibration is not there but the angle of car does not change as when you have car on ground under load??
It's not a good idea to run the car in gear unless the spindle assemblies are supported.
The angles I referred to are at either end of the driveshaft, which means the angles don't change depending on the incline of the car, since the trans and the dif are bolted to the frame.
Has the shop checked for matching driveshaft angles in the 1° to 3° range? Have they checked for cracked engine mounts? At what rpm does the vibration occur? In what gear? At what speed?
Old May 20, 2007 | 06:24 PM
67L36Driver's Avatar
67L36Driver
Running in gear with the half shafts hanging, it's a wonder it don't shake itself off the jack stands.
Old May 21, 2007 | 04:46 PM
blubu's Avatar
blubu
Default whls hanging
First I did have stands under car to support both rear axles.
The axles were not hanging as you say. I m not saying what I did was good idea. NO they did not check the angles of driveshaft and rear in the one to three range. Yes mounts are good. If you throttle it in any gear when the nose comes up on car.You can feel it in the car.
The car has a 4.10 it will run down the highway wo a problem other than rpm. But from dead stop when you move out and under hard throttle. You can feel it in any gear.I wish I could explain it better.
Old May 21, 2007 | 04:51 PM
knight37128's Avatar
knight37128
How much does the front end come up during acceleration?
You may have weak springs.
Old May 21, 2007 | 10:42 PM
blubu's Avatar
blubu
Default vibration
It does not seem excessive the car transfers well.
The car will run down the road fine at most any rpm
When you stand on it is when you feel it
In any gear, I am at a loss Most of the problems I describe
With my car?? No one else has or does not care to answer
I think I may be the only one with such problems.
Old May 21, 2007 | 11:28 PM
magicv8's Avatar
magicv8
IMO vibration under acceleration is normally electrical (ignition) malfunction - bad wire, plug, cap, timing, coil - check in that order.
PS Lots of people have had the problem.
Old May 22, 2007 | 09:23 AM
wombvette's Avatar
wombvette
Too much negative camber and or weak springs will cause vibrations under load. It binds the U joints.
Old May 22, 2007 | 09:44 AM
knight37128
Drag racers used to put weaker springs in to get the car to transfer weight.
If your car tries to lift the wheels when you stomp it, you have weak springs. Have you tried to lift the car by hand?
Old May 22, 2007 | 11:20 AM
MasterDave's Avatar
MasterDave
Moderator
I'm leaning towards 'torque', as in when you step on it your third member torques up. If the rubber doughnut is no good you're probably getting vibration thru the rubber to the body.
Old May 22, 2007 | 01:03 PM
JohnZ's Avatar
JohnZ
Especially if you have the poorly-designed and incorrectly-manufactured "poly" diff bracket-to-frame bushings.
Old May 22, 2007 | 01:53 PM
blubu's Avatar
blubu
Default biscuit
I have replaced the for want of a better term the biscuit between the nose of rear and frame upper and lower. I bought mine from Mid America
My old one had chatter marks on the steel sleeve where it had been working I was elated . But that did not fix it. The one I bought was the black one. I dont remember anything special about it though. As of late I replaced the bolt making sure the diameter fit sleeve. No help. The problem seems to be in the rear of car motor does not skip a beat or misfire. She runs well. I always thought the transfer of weight had more to do with car having 4.10 gears than weak springs?? Suspension is fresh.
To Vibration help - moved from Hurst thread
