63 Speedo Problem
New speedo cable, new Odometer and trip odometer, I took the speedo apart and cleaned the gears last winter. The speedo needle would seem to need to “warm up” as you started out cold. When going say what I would judge to be 50MPH, it would slowly make its way from 0 to about 40-45MPH and then seem to work fine. I put about 300 miles on it this way, it made no noises, just ran slow and needed to “warm up”. I have a 3.36 rear end, 205-75-15 tires, and no idea what speedo gear in the tranny, so being a bit slow was not a surprise.
Why would the needle stop- it doesn’t move up or down now?
Don
Just got mine back in and was trying out when rear spring broke. Had a forum member Gldnkngt fix my odometer and trip meter that wasn't working and tach that was off and I'm EXTREMELY HAPPY still have a smidgen of speedo hand bounce, think I pulled a little to hard on it while putting things back together, I was a little frustrated with the cramped space. Bill (gldnkngt@comcast.net) down in Jupiter, FL harrisonspeedometer.com had great turn-around time. Faces came back looking like new, the tape on my number wheels was starting to flake off so he didn't them. Price he charged was more than fair! If I had a tail it would be wagging!!!
Just be careful of that whileImatit disease,
Good Luck,
Andy
Don
As someone who has replaced my entire new dash harness with a borrowed one, just to run a test, before putting my new harness back in, I feel your pain.
I don't know if swearing helped, but I was glad I was working with all the garage doors shut in order to contain my colorful display of frustration
Don
