Clock Restoration
Old Jun 17, 2007 | 11:44 PM
Itza66's Avatar
Itza66
Default Clock Restoration
The clock in my 66 Coupe is not working. I took it out Today and I am wondering where I can send it to be restored. Please let me know your experiences. Thanks!
Old Jun 17, 2007 | 11:57 PM
Red63SW's Avatar
Red63SW
Zip and Ecklers do it. There are other sources, too. Mine is at Zip right now for a quartz conversion and cosmetic resto. I expect it back in about 2 weeks. I'll let you know how they did on it.
Old Jun 18, 2007 | 12:22 AM
SPLITRAY's Avatar
SPLITRAY
You can get a quartz conversion kit and do it your self for about $50.00 and 1 hours work. Mine works great!
Old Jun 18, 2007 | 07:28 AM
Mike Terry's Avatar
Mike Terry
I think the best place to send it would be to Corvette Clocks by Roger. Roger Reed does a great job, he did all the gauges and clock on my 63 coupe www.corvettecolcks.com
Old Jun 18, 2007 | 07:39 AM
63driver's Avatar
63driver
As stated you can do a Quartz conversion. It's a straight forward change. I changed over and when I had the clock restored I went back to the original movement.
But if the lens needs to be changed, the face needs paint and the bezel is scratched send it out. Shop around, most places have a fixed price for a clock.
Try Joe Ray at http://joerayparts.com/ he does great work at a fair price.
Harry
Old Jun 18, 2007 | 07:44 AM
Tom/99's Avatar
Tom/99
I did mine 8 years ago, it still keeps perfect time.
Old Jun 18, 2007 | 10:56 AM
CaveCreekChump's Avatar
CaveCreekChump
This was my choice also. Very pleased with the result.
Old Jun 18, 2007 | 11:23 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Can the quartz conversion be done if the set-stem is not functioning now. My stem is missing whatever goes on the inside end (a gear maybe?) and can be pulled out of the clock. Does the quartz unit do away with the need of the original set-stem or would I have the same problem I have now? By the way, my clock does work but disconnecting the battery to set the time sucks!! Thanks for any info.
Old Jun 18, 2007 | 01:18 PM
NSPharmD's Avatar
NSPharmD
Have had the clocks done by roger for 5 vettes now, and just gave him all my gauges and clock for my 54. He does awesome work.
Old Jun 18, 2007 | 01:29 PM
ucc2ic65's Avatar
ucc2ic65
I had my clock done this spring by Clocks by Roger. I took about four weeks to get it back. I got it back on a Friday and installed it that night. The next day while out crusin the clock fell apart (the front and back sections separated). I removed it, contacted them and sent it back. Because it fell apart the day after I received it, I asked them to fix and return ASAP, reimburse me for the cost to ship the clock back to them, and not to be charged the return shipping. I got the clock back about a week later, they did not charge me for shipping it back to me, but they would only reimburse me for a portion of the cost to ship it back to them (reimbursed me approx. 67%).
Old Jun 18, 2007 | 06:03 PM
gldnkngt's Avatar
gldnkngt
Let me know if I can help. I can restore these. Turn-around time about 5 days once I get it + shipping time back to you. I agree, quartz conversion is the way to go. Check my profile for my website and info.
Old Jun 18, 2007 | 06:10 PM
gldnkngt's Avatar
gldnkngt
either way, leaving it original or converting to quartz, you need to have a working set stem and pinion gear. I'd suggest replacing both. The pinion gear is pressed on internally, and if you don't replace the stem as well, whatever made it come of in the first place may happen again.
Old Jun 18, 2007 | 07:22 PM
SPLITRAY's Avatar
SPLITRAY
There is a small gear on the stem, but I'm guessing that it's the mating gear your having trouble with. (I forget how the stem gear is attached to the stem, but I do suppose it could have come loose). My conversion did give me a problem with the new mating gear because of dimemsional differences.
It was an easy fix though. I purchased a couple of small nylon washers and filed one down until it took up the space behind the clock face with only .003"-.005" clearance. The stem gear engages every time now, perfectly.
Old Jun 18, 2007 | 11:27 PM
sweet66's Avatar
sweet66
Default Tick Tock Clock.
In 04 I packed up my inoperative clock and sent it to " The Clockworks"
in Eagle River WI .. Jerry Magayne installed a new Borg Movement ,New lens , painted the black bezel Total with S/H $116.95 looked like new
It keeps good time and unlike the Quartz movement does tick tock like original [ quartz has continuous sweep second hand unlike stock if you are big on that sort of thing] phone is 715-479-5759
WWW.CLOCKWKS.COM
Old Jun 19, 2007 | 12:30 PM
Thomas66's Avatar
Thomas66
If you use Roger, have him restore your clock. I did a show trade. When I got home and unwrapped it, I found that the bezel was a piece of crap compared to the newer one on clock I had traded in.
To Clock Restoration
