Ignition switch help
Old Jun 30, 2007 | 04:40 PM
Lee H's Avatar
Lee H
Default Ignition switch help
The ignition switch failed in my 65. Radio and other stuff would not turn off in the off position. I purchased a switch from NAPA and all went in OK. The car starts when turned to the start position but stops when released to the on position. Any thoughs? Thanks, Lee
Old Jun 30, 2007 | 05:40 PM
54greg's Avatar
54greg
Old Jun 30, 2007 | 05:43 PM
62Jeff's Avatar
62Jeff
Wow, normally I'd say that's a classic sign of a bad ballast resistor, but I can't imagine it going bad at the same time your switch did.
I'm all ears on this one too I'm afraid.
SPLITRAY's Avatar
SPLITRAY
Sounds like the IGN wire (coil) is wired to the start term.
Old Jun 30, 2007 | 05:50 PM
MikeM's Avatar
MikeM
Get a test light and work your way back toward the switch starting at the + post on the coil. Through the ballast, through the bulkhead connector and on to the switch with the key "on".
Old Jun 30, 2007 | 06:08 PM
Lee H's Avatar
Lee H
Solved, I went to Autozone and bought another switch and it works. Thanks all for the help. This forum is great.
To Ignition switch help
