Decking The Engine Block...
. i would be pissed if i looked at my engine and it had the right number stamped on the pad, i would have to start replacing the 1000 other non origonal parts on the car and stop driving it, buy a trailer, get obsessed with ncrs, just to have the judge say " that paint on your knuter doesnt have the right gloss, thats a 200 point deduction" id end up like this.
. if you cant beat the snot out of it its not a vette
Al W.
If it is not documented to be original block that came with the car "matching numbers" advertisement is a good indication to look for a scam to get your money
Doug
I appreciate the numbers correct people and may the Lord bless them. I am just not one of them.
Here is my take on it. I would pay you 50K for an all correct 67 435HP coupe. It is a used car, make that a valueable used car.
I would pay you 100K for a properly constructed restomod on a modern chassis like an SRIII with modern engine and drive train and braking system. Once you have constructed this vehicle and driven it it is a used car. Make that a valueable used car (to me).
I gotta go along with if the NCRS accepts restamped blocks of a "correct" period then to me they are actually endorsing fraud which is a crime. After all, we all know that only one block left the factory in that car with that number stamped into it. Now that there are two carrying the number one of them is a fraud.
The numbers matching thing has been beaten to death again and again and I am not intending to restart it. I simply tell you where I come from.
When I worked in an automotive machine shop in the late 60's, 70's and early 80's we used a Storm Vulcan manufactured machine for block resurfacing (decking). The machine used a segmented grinding wheel and aligned the deck surface with the main saddles as the mounting platform ran directly through the main saddles. We could control the movement of the block forward and reverse and could stop the grinding/cutting action of the machine prior to engaging the stamp pad. SOOOOO, you could deck a block and maintain the original numbers in the block if you wanted that. I don't have experience with other machines so I don't know what their control abilities were relating to saving the pad.
We CAN all get along. But we do NOT have to agree on everything.
Rich
A bridgeport is definitly not the right machine to use. A bridgeport is a Knee type mill which has the table supported in the middle by a screw that allows for the table to be raised and lowered. This machine type had it's uses in it's day but any heavy work always caused the table to sag on one side or the other depending on where the weight was. Using a bridgeport would almost guarantee that the deck would not be flat.
If a block needs to be decked, I would have it decked and I would make sure that before it is decked that a cast of the numbers was made, that was accurate and clean. I would then have the block decked and I would grain the stamp pad to mimick the broach that originaly decked the block. I would then have the cast of the numbers used to creat an exact positive of the original numbers using an EDM machine. I would then have that stamp pad pressed into the block to give you the exact pattern that you had before.
To have a numbers matching block running with a warped deck just to protect the numbers is short sighted in my oppinion, as the head gasket with uneaven preasure could let go at any time and cause the block to overheat and crack. The other problem with a warped deck, is that it could also cause your heads to crack.
If you want to save your investment and keep the numbers, I have shown you the way that it can be done while getting the motor right. The process that I described, would not be cheap, but if you want the original stamp it's the only way. Now I know that some will say that this method would not be the original stamp... but who could tell, it would be the identical stamp that was there before and who cares if it was stamped 40 years ago or redone as an exact duplicate of the original stamp a year ago.
Yea, but would you give away $10K in vaule of you car is the bigger question! There are lots of people who would not pay a premium for a numbers matching engine, but not very many that would willingly give away $10K in value if they already owned one! Your response, basically telling this guy to flush his money down the drain, is crazy! Of course, it is not your money!
Regards, John McGraw
