My speedometer is as much as 10-15 MPH slow Does not bounce around but is just slow. Would i check the green(370) gear in transmission first or would it be something else thanks
Speedometer gears: You may have to change the drive gear, unless you can put a gear on the cable that will get you within 10% of being correct. There is a 3890575 small GM gear drive that was used to get a 4.56 to work with a 4.11 cable gear. Let me know if you need it.
ratio__tire size___drive gr_____driven gr_teeth_color
2.73__8.15-G70__3895494____3987918_18____brown
3.08__7.75 -15___3924098____3987918_18____brown
3.31__8.45-G70__3924098____3987919_19____natural
3.36__8.15-G70__3924098____3987920_20____blue
3.55__8.15-G70__3924098____3860344_21____red
3.70__8.15-G70__3924097____3860345_22____green
3.70__8.45-_____ 3924098____3860344_21____red
3.73__8.15-G70__3924097____3860345_22____green
3.73__F70______ 3924097____3860348_25____orange
4.10__8.15-G70__3924097____3860347_24____yellow
4.11__F70______ 3924097____3860348_25____orange
4.56__8.15-G70__3924097____3860345_22____green* uses 3890575 adapter
I've got the same problem on my 57. From the best I can determine, my rear end has a 3.08 ratio. Does anyone know if the speedometer gears MagicV8 lists will work on a 57 (or a 58 - think my 3spd may have come from a 58)? Also, will a Chevy dealer still carry the gears?
Don't mean to hijack this thread but I am confused. My M20 in the 65 appears to have only 5 teeth on the drive gear. 5 teeth is not an option on the web site listed. What am I missing?
According to my GM parts manual the 3987918 gear fits 61-67 corvettes with 3 speed transmissions. The only gear listed specifically for a 57-60 Corvette in the manual is a steel 20 tooth for a 4.56:1 diff - so no info there. All my old Motor's manual says about part numbers is "various".
Besides the speedometer gear that is a possibility how about does your odometer work? If not this can cause a problem as the speedometer and the odometer are driven by the same assy. Dave
If a 6 tooth will take the speedo up to 4.56:1 diffs, maybe it's for a 4.89:1 diff???
It does not work. You may have something here My 67 did not work either and i pulled the cluster and fixed it, i may have to do it again .i may be coming down your way pretty soon
Not sure what came in the car but it has a 3.08 in it now. The driven gear is a brown 18 tooth and the tach reads around 2300@60mph. Tires are 255/60, 27" diameter. The speedo is only about 3 mph high to actual, checked with a GPS and a laptop. Does all that make sense?
