I am going to change the Battery in our 2004 Yukon. Do I need to keep 12 Volts in the system while replacing Battery? (I struggle with these Newer cars!). LOL Al W.
You don't "have" to, but it sure is a good idea. The problem is the ECM will be "reset", and will have to relearn all over again. Some vehicles may lose the presets on the radio, etc.
You can use a standard 9 Volt battery, rather than a 12 Volt (as long as you don't leave the big battery disconnected for longer than necessary.
Make sure you know your radio security code before you begin if you completely disconnect without a temp power source.
Depends on the vehicle - some have capacitors in the computer which maintain settings for a while even if the battery is disconnected. My '00 Cherokee does this, if you actually want to dump the computer memory you have to do a weird dance involving disconnecting the battery and playing around with the headlight and ignition switches.
