front spindle differences?
Old Oct 4, 2007 | 05:05 PM
needforspeed150's Avatar
needforspeed150
Default front spindle differences?
Does anyone know if their are any differences in the disc brake spindles for c2 and c3? I know they use different bearings after 1969 but is that the only difference?
Thanks for the input
Ben Russell
Old Oct 4, 2007 | 05:09 PM
Vogie's Avatar
Vogie
I am not technically qualified to answer your question, but if no one else responds, call VanSteel and ask. Good Luck.
Old Oct 4, 2007 | 05:13 PM
JohnZ's Avatar
JohnZ
Ben Russell
The only difference is the spindle diameter (and thus the bearings).
Edit: Oops, forgot - the steering arm bolt holes are larger too.
Old Oct 4, 2007 | 05:37 PM
redvetracr's Avatar
redvetracr
how about the two holes for the steering arm?? in 1969 they became 1/2".
redvetracr
Old Oct 4, 2007 | 06:24 PM
Wilkinshc's Avatar
Wilkinshc
Also the hubs are different. FYI the rear hubs are also stronger on the later c3's (more solid).
When I went to the c3 front spindles I needed:
spindles, hubs & bearings, and steering arms.
Hope that helps.
Chuck
Old Oct 5, 2007 | 12:03 AM
Steve439's Avatar
Steve439
Old Oct 5, 2007 | 12:11 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Just for clarification, didn't the 68s still use the small spindles and bearings?
And why does a Corvette need 3/4-ton truck rated bearings, anyway? 1/2-ton GM trucks of the era used smaller front spindles than 69-82 Corvettes.
Old Oct 5, 2007 | 12:16 AM
Steve439's Avatar
Steve439
Yeah, they changed in 69.
Cornering stress, I'd guess...
Old Oct 5, 2007 | 12:23 AM
Steve439's Avatar
Steve439
Oh - are you talking about the bearing support change?
The later ones weigh more but I didn't know they are stronger...
Old Oct 5, 2007 | 02:31 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Seems like overkill. Were racing C2s experiencing a lot of strange bearing wear?
Old Oct 5, 2007 | 10:08 AM
Steve439's Avatar
Steve439
That's a good question.
You'd think if they went to that much trouble 1/2" studs would have been worth it too.
Old Oct 5, 2007 | 02:10 PM
63Corvette's Avatar
63Corvette
Mag wheels with lotsa offset and leaning hard on real sticky tires in the turns have cost me a LOT of wheel bearings over the last 40 years.....and some axles too.
Old Oct 5, 2007 | 02:48 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Go around the banking of Pocono at what 130-140 mph with 10" slicks on the front and then talk to me about bigger bearings. BTW, I never broke a 7/16 stud. If I had I probably wouldn't be able to tell this story.
Old Oct 5, 2007 | 05:42 PM
Vogie's Avatar
Vogie
The Chevrolet Power Manual (now out of print) recommends the later model spindles and hubs in the Corvette race preparation section.
Old Oct 5, 2007 | 06:01 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Exactly. Since my AR wheels aren't hub-centric, I've upgraded to 1/2" studs. Not the most fun job I've ever done on my car... C4s finally got the 1/2" studs, I have no idea why C3s were stuck with dinky 7/16" studs (with very small splined areas) while using those enormous spindles. It doesn't seem to make a lot of sense from an engineering standpoint.
Lightweight 001's Avatar
Lightweight 001
For the record there were three different front spindles used from 65-82. The 65-67 used the small bearing spindles and hubs. The holes through the spindle for the steering knuckle were 7/16". In 68 the spindle still used the small bearing spindle and hubs but the steering knuckle holes were 1/2" From 69-82 they were all large bearing spindles and hubs and the holes were 1/2" If you guys need any of them we are a supporting vendor and offer our prices with no core charge and free shipping.
www.duntovmotors.com
Old Oct 5, 2007 | 06:02 PM
Wilkinshc's Avatar
Wilkinshc
Exactly, if you look inside there is alot more material. Sorry it took so long to answer.
Chuck
Old Oct 5, 2007 | 06:59 PM
needforspeed150
Thanks for all the response guys.
Great help.
To front spindle differences?
