Overheating Problem Solved
Dennis
It is near impossible to find a clutch to work with the fan, as most all clutches are setup for a 5/8" pilot from the waterpump, while the late-model Corvette water pump uses a 3/4" pilot. I have just bored the clutch out to 3/4" pilot and they worked fine. The clutch really keeps the fan noise down on the highway. Flex-a-lite makes a really good stock-type fan for reverse rotation that will move a huge ammont of air when the clutch is activated. It is # 5917, and is not a flex fan, but must be used with a thermal clutch, or the roar will drive you to drink!
Regards, John McGraw
Not to rehash anything but the questions are always radiator, timing, hoses, thermostat, hot spots in block, and the list goes on. Guys I tried everything rechecked it all.
I can only tell you everything is new factory or better, or at least I thought.
The car would go to 240 degrees + in a heart beat on the freeway. One would conclude that with this amount of air coming through at 70 mph + that should not happen.
I came to the conclusion that I needed to replace the electric fan that came with the brand new Dewitt radiator. The fan could only turn as fast as the elect. motor would let it. I believe the elect fan was fighting the air and not it letting through, and or disturbing the air flow.
I took the radiator out, removed the Dewitt fan and replaced it with a flex fan and installed it as originally designed by GM.
Do I need to say more, I can't even get it to 180 degrees.
I spent untold hours going everything, taking apart, spending $$ by taking it to others to check this and that. I purchased and spent good money for a product that was suppose to be state of art and would work on a stock engine rebuilt to factory specs.
Would like to hear what you all think about this, and how many have been as frustrated as I am right now knowing that again a product that you pay good money for, that is suppose to function as advertised does not.
Dennis
I wa shocked to find out tat the temp was droped to t-state level even in traffic gos below 180F amazing
If you need more inform about the fan part # you are most welcome .
but there is one thing I need to highlight and I need the expert view on this . the new blads are heavy will it affect the water pump?
thanks
Omar
Bill
Not true, here is why...
He said the AC added a load onto the radiator and that's right. So you have a choice, add 100% of the AC load to the radiator, or allow some to escape. I'd go the escape route. You will also pick up some new air for the radiator, which will also help.
i recently spaced my condenser out an additional inch (more would be better, but i'm limited by working room) from the radiator; the jury is still out as daytime temps have dropped dramatically and my 'hotter than i'd like it' problem only occurs around town in traffic. so, it may be next year before i really know if it helps; early indications are that it has stabilized temps a bit, and the heat soak temp rise from shutdown seems to pull down quicker.
Bill
thanks
Omar
I am now using a Stewart cast iron pump that bolts right on in place of the factory pump, but has a reinforced housing and a larger front bearing. I recommend it if you have problems
The condenser is in front of the radiator support. The drawing is somewhat misleading for the expected airflow direction.
The normal puller fan develops a negative pressure area downstream of the radiator. All the airflow travels from high pressure to low pressure. Airflow travels inward from the sides of the condenser to mix in the gap between the condenser and radiator, before being pulled through the radiator.
The condenser has high bypass ratio or bypass factor, much more than the radiator. This means a high ratio of untreated air (air not picking up heat in this case) passes through the condenser compared to the percentage of treated (heated) air. This is one reason why the condenser is so large, by design, compared to the evaporator (or cooling) coil inside the AC blower ducting - because it is designed to bypass a high ratio of untreated air. The bypass air and heated air mixes after it leaves the condenser, leaving only mildly heated air to continue through the radiator.
Take the two effects of the above paragraphs and combine them: untreated airflow entering the sides of the gap between the condenser and radiator, mixing with the high bypass percentage of airflow traveling through the condenser. The result is the temperature gain of the mixed airflow between the condenser and radiator, the air entering the radiator, is much lower than if you close coupled the condenser and radiator heat exchange surfaces.
A wider the gap between the condenser and radiator allows more untreated (unheated) mixed airflow and a lower airflow temperature entering the radiator. Good for radiator heat exchange.
If a condenser is replaced with a model that is larger in face area (that holds the same volume of refrigerant) it can be designed to have a higher bypass ratio and the temperature of mixed airflow on the downstream side of the condenser will be lower. Again, good for radiator heat exchange.
Clear as mud?
I trust this helps.
wmf62, you are correct... with a big gap between the condenser and radiator, you need a fan on the condener if you want any a/c at idle (with no seal between condenser and radiator).
Excellent idea! good work Bill
My drawing may be flawed but the illustration was simply to say, don't seal up all the gaps between the radiator and the condensor. The radiator would like some fresh air. Not to be confused with sealing the radiator to the core support, that is a good idea. Not so much for drawing in compartment air, but rather stoping air from just going around the radiator instead of thru it.
At this point I'd be tempted to repeat your "
Whatever", but that whole 'do unto others' thing...
In addition someone added that the fan had more blades to support this application.
Dennis
I said "i.e. the condenser can be inside or outside the core support." Are we going to argue symantics of the word "can" ?? Or is the fault with my use of "i.e." instead of "e.g" ??
