Overheating Problem Solved
Old Oct 12, 2007 | 09:19 PM
  #121
magicv8's Avatar
magicv8
Originally Posted by mhamilton
Are we going to argue symantics of the word "can" ?? Or is the fault with my use of "i.e." instead of "e.g" ??
Yes the fault is in the Latin usage. You should have used "exempli gratia" instead of "id est" but "mea culpa" will work now.
PS: IMO this thread is
Old Oct 13, 2007 | 01:24 AM
  #122
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It would have been really nice if the drawing had this small addition:
And what I was thinking of (the C3 radiator mounting) would have the two heavy lines for the core support positioned almost in the center between the condensor and radiator, allowing air to be pulled around both units without a seal.
Old Aug 29, 2009 | 05:52 PM
  #123
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
I am having cooling issues with my recently built 63 convertible. Seems to have the original radiator. Is it crucial to have an aluminum replacement?
Old Aug 29, 2009 | 05:57 PM
  #124
62Jeff's Avatar
62Jeff
Howdy,
This should address that question for you. This link discusses the merits and includes data indicating a brass replacement radiator has 30% less BTU rating from a factory aluminum radiator.
http://www.dewitts.com/pages/whyaluminum.asp
Jeff
Old Aug 29, 2009 | 06:34 PM
  #125
MiguelsC2's Avatar
MiguelsC2
Did the 63 come with an aluminum radiator originaly?
Old Aug 29, 2009 | 06:54 PM
  #126
Ironcross's Avatar
Ironcross
.Are you doing well counselor?
. i`m sure you are....
Old Aug 29, 2009 | 06:59 PM
  #127
Ron Miller's Avatar
Ron Miller
Yes
